blue spring
Old May 28, 2012 | 09:59 PM
cefloyd's Avatar
cefloyd
blue spring
Hi I have been looking at prices on a blue spring upgrade and came across this web page Riffraff Diesel: Ford Fuel Pressure Regulator Blue Spring Kit=
price was 29.88 and also been looking at tousley ford price is 52.80 I was just wondering if the one that is 29.88 as good as the one from a ford dealer?and also how hard are they to change and any special tools?thanks and God Bless!!!
Old May 29, 2012 | 12:07 AM
Yahiko's Avatar
Yahiko
Hi,
I am going to guess that the cost could be lower because I did not see a cover
in the one at Riffraff.
That upgrade is on my list as soon as I find out if it has been done or not.
Here is a video on the install
Sean
fuel regulator spring upgrade, Ford 6.0L powerstroke - YouTube
Old May 29, 2012 | 05:59 AM
zhilton's Avatar
zhilton
The difference in price is the one that RiffRaff has listed is without the cover. And unless you've done something to yours...the cover is designed to be reused; it's made of aluminum. You don't need any special tools, but will find it allot easier if you use a bungee cord to pull the upper radiator hose down out of your way. Drain the secondary filter housing (use a turkey baster) before you pull the regulator cover or you'll have diesel everywhere.
Old May 29, 2012 | 04:17 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
any special tools?
T27 torx bit. My cheap set of torx keys in 1/4" sockets didn't have one and I had to pick up a single.
I used a ratchet strap around the upper rad hose and pulled it down, tied off to the front tow eye.
diesel_dan
Feb 25, 2013 04:15 PM
kbuchheit
Aug 8, 2012 01:03 AM
IT_Dude
Aug 24, 2011 08:52 PM
_Me2_
Dec 14, 2010 11:49 AM
mike330
Aftermarket Products
Jan 26, 2008 11:25 AM
