Blue spring upgrade instructions
Old Feb 25, 2012 | 06:16 PM
kbuchheit's Avatar
kbuchheit
OK guys, I know I have read about this at least 20 times but I can't seem to find it now.
I would like to do a blue spring upgrade on my late 2004 F350 6.0
Can anybody tell me how its done and where to get the parts?
Thanks!
Old Feb 25, 2012 | 06:30 PM
zhilton's Avatar
zhilton
My preferred vendor is RiffRaff, and here's what he carries..
With cover
Riffraff Diesel: Ford Fuel Pressure Regulator Blue Spring Kit
Without cover
Unless your old cover is cracked or has something broken on it...you shouldn't need the cover. I think the replacement is pretty straight forward with the diagram supplied with the parts. Been trying to see if I can find a photo instruction link...but no luck yet.
Old Feb 25, 2012 | 06:39 PM
kbuchheit's Avatar
kbuchheit
Thanks!
I will try to get it ordered this week.
Is it located on the frame fuel pump or somewhere else?
Old Feb 25, 2012 | 09:08 PM
BLADE35's Avatar
BLADE35
Originally Posted by kbuchheit
Thanks!
Its location is at the Upper Fuel filter housing
Read this
Good BLUE spring with pics
Fuel Regulator Upgrade w/ Pictures - Diesel Forum - TheDieselStop.com
Old Feb 25, 2012 | 11:07 PM
kbuchheit's Avatar
kbuchheit
Thanks!
The pictures helped a lot. I will try to get to it next week.
Old Jul 31, 2012 | 10:57 PM
PattonC222's Avatar
PattonC222
I am going to do this upgrade tomorrow and I have a question about it.
I know I will not be using every o-ring etc. with the kit(I have the one without the new cover). But looking at the link that Blade posted in this thread got me thinking, it appears that I don't need half of what is in this kit. See last picture that says old parts removed. I know it's a simple procedure I just want to make sure all my ducks are in a row. Thanks.
Old Jul 31, 2012 | 11:04 PM
PattonC222's Avatar
PattonC222
Repost....
Old Aug 1, 2012 | 02:58 AM
Yahiko's Avatar
Yahiko
some things I found very helpful.
Rusty said to have a few shop towels around the
back to catch dribbles and any dropped parts. Next
Very helpful because I almost dropped the nut is a zip tie
on the fuel line to keep the nut in reach.
Very happy I did not have to go fishing for it.
Sean
Old Aug 1, 2012 | 06:41 AM
WH 6.0's Avatar
WH 6.0
Sean
Yes definitely remember to put the zip tie on the fuel line to keep the nut from sliding down. I forgot to do it and "fishing" that nut back up the fuel line turned out to be the most frustrating part of the job.
Old Aug 1, 2012 | 11:25 AM
PattonC222's Avatar
PattonC222
Ok last question, Can I get by with just replacing what is under the cover? The diagram I have also shows replacement of 4 o-rings on the right side of the housing also. I have looked at a few things and I am getting some mixed info. Also thanks for the zip tie trick I will definitely be using that.
Old Aug 1, 2012 | 11:53 AM
fordtruckrodder's Avatar
fordtruckrodder
Take a look at this link, this is a well done article with clear pictures.
https://www.ford-trucks.com/forums/1...ue-spring.html
Old Aug 1, 2012 | 12:22 PM
wakeupluis's Avatar
wakeupluis
Patton, I did the blue spring kit on my truck about 2 weeks ago. Very very simple. If your stock o-rings are fine. I would not worry about buying new ones. Mine came with the kit. So I replaced them. I bought the complete kit with new housing. I am sure I did not need any of the parts but the spring. I did have an extra peice that was not on my truck. So left it out. This job took about 20 minutes start to finish. Only thing I removed was the air filter housing and intake plumbing from the intercooler to the intake. I am no mechanic. But I do my own wrenching. Very easy to do. Just replace what you took off with new.
I did use a hand vacuum pump that I got from Autozone to suck out the deisel that was in the housing. I heard people using turkey basters or what not. I think the cheap $20 vacuum pump is a must have in anyones tool box. I use it to bleed brakes. Works for lots of things.
Old Aug 1, 2012 | 12:49 PM
PattonC222's Avatar
PattonC222
Yeah I figured about the same as you as to what is involved, just got confused with all the extra o-rings. Just don't want to overlook anything. Thanks for the info.
Old Aug 1, 2012 | 01:40 PM
zhilton's Avatar
zhilton
The extra o-rings are for different versions of the filter housing that use the same pressure regulator; there are certain o-rings that will be left over.
Old Aug 1, 2012 | 04:53 PM
metmop's Avatar
metmop
I think Ford just knows us back yard mechanics..... we aren't happy unless there is a few "SPARE" parts left after a job
