He351?
Old May 28, 2012 | 05:36 PM
f1501987's Avatar
f1501987
He351?
Would I have to do alot to get a he351 turbo to fit my truck. Its stock off a 2500 cummings
Old May 28, 2012 | 06:44 PM
fordpride's Avatar
fordpride
Do you meen HX-35? If so you would have to build a pedestal, uppipe with a t4i mount, downpipe, intake spyder, and plumb in the oil feed an return
Old May 28, 2012 | 07:29 PM
BuckHammer's Avatar
BuckHammer
You mean "Cummins"?
Old May 28, 2012 | 08:12 PM
bad12jr's Avatar
bad12jr
yes you would. But there is no benefit from it as it is a smaller inducer Turbo. Has a small exhaust side. Is a vgt Turbo so a controller of some sort would be needed.
Old May 28, 2012 | 11:26 PM
fordman67's Avatar
fordman67
Hx35 is the not variable.i have one here if yoj want a pick
Old May 29, 2012 | 12:27 AM
Ford4Life7.3's Avatar
Ford4Life7.3
Originally Posted by BuckHammer
You mean "Cummins"?
Its my pet peeve too...idk where people get the idea theres a g!
Old May 29, 2012 | 03:33 AM
tjc transport's Avatar
tjc transport
i ain't rite
most people get the idea there is a "G" in cummings off of the back window of the dodges with the big CUMMINGS stickers on them.
Old May 29, 2012 | 03:36 AM
bad12jr's Avatar
bad12jr
He351 is a variable vane charger off of commonrail cummins. Hx35 was on 1994 to 1998 12valve. Iirc the 24valve had an hx40.
Old May 29, 2012 | 03:53 AM
f1501987's Avatar
f1501987
Its off a newer dodge. But if it won't give me anything better,ill keep nine
Old May 29, 2012 | 04:00 AM
bad12jr's Avatar
bad12jr
Iirc its on like a 56mm or maybe even 54mm inducer. Our stock charger is 60mm. A good upgrade would be an s366 Borg Warner charger. But would require a t4 mount or if you good at fabbing make your own mount.
Old May 29, 2012 | 03:35 PM
strokin'_tatsch's Avatar
strokin'_tatsch
The 8 blade HX-35's came on the 12v and I believe the 7 blade compressor HX-35 came on the 24v VP44 trucks. I think there was also the HY-35 that came on the '01-'02 automatic trucks that had a non divided turbine housing. Not sure that I've ever seen an HY-35 before, but I've heard about them.
The HE341 came out on the Common rails in '03 and '04 (Smaller than HE351, but don't have specs right now), then they switched to the HE351 in '04.5 and later models.
I think the HE351 had a 60mm inducer on the compressor wheel, but the exhaust side was tiny... I think the turbine wheel was somewhere around 60mm and the turbine housing was around 9cm.. The HE351 is NOT a VGT turbo.
The HE351VE is the VGT version that comes on the 6.7L Cummins.
Personally, I wouldn't bother with any of those turbos on a 7.3L. They just aren't big enough. The HE351VE might be big enough when the VGT is fully open, I don't know, but I wouldn't bother trying it. There are much better options to swap to such as the HX50 or HX55, H2E, and of course an S300 or an S400..
Old May 29, 2012 | 06:35 PM
bad12jr's Avatar
bad12jr
Thanks Travis. Need to read up on my cummins stuff some more.
Old May 30, 2012 | 04:12 PM
strokin'_tatsch
There is a thread going on another forum about the Dmax turbos and retrofitting them on the 7.3L. I've never seen a Dmax turbo in person, but they sound like they could be a good fit if one could get the VGT working on it. The stock Dmax turbo is a VGT Garrett 4094 and has a 66mm compressor wheel. There are also a bunch of performance upgrades out there for it. I think if i was going to try a turbo off of another light duty diesel platform or if I was going to try VGT, I would try that Dmax turbo.
Old May 30, 2012 | 04:21 PM
Ford4Life7.3
I have an H2E for you
Old May 30, 2012 | 05:31 PM
bad12jr's Avatar
bad12jr
I thought the inducer was 60mm but fleece can mod them fairly reasonably.
