Kinpin replacement questions, please help
Old May 28, 2012 | 03:19 PM
zukinut's Avatar
zukinut
Gotta replace the kingpins on my 68 F350. I have read the factory service manual and a few online tutorials and Im positive I can do it myself. My one question tho is, How do I know what size reamer I need to ream the bushings? Does anybody know. Does anybody know where i can look to find out?
Thanks in advance.
Will
Old May 28, 2012 | 05:53 PM
f5fordgirl's Avatar
f5fordgirl
Take the spindles, along with the new bushings and pins to the machine shop, they can press them in and ream them to a precise fit, paid 50 dollars to have my 49 F-5's done.
Old May 29, 2012 | 05:36 AM
elgemcdlf's Avatar
elgemcdlf
It is not worth buying the tools unless you plan on doing a bunch of them. Machine shop is a good move in this case. I do not know the exact size reamer you need but it will be just slightly larger than the pin. I mean very slightly larger as in just enough so you can get the pin in with no wobble.
Old May 30, 2012 | 05:10 AM
nobearsyet's Avatar
nobearsyet
Besides, the machine shop has probably done several, and knows how to jig it to get your caster right.
Old May 30, 2012 | 08:05 AM
6t6merc's Avatar
6t6merc
Getting pins out.
I have this job in my near future too. I'll go to a well-equipped shop because my friend just did it, said the shop press showed 40 T when it came loose. I can't swing a hammer that hard!
Eric
Old May 30, 2012 | 09:32 AM
nobearsyet's Avatar
nobearsyet
BTW FWIW get the kit with the metal bushings, they last forever if you keep them greased, the nylon ones you'll basically be changing with your spark plugs.
red-bulli-69
May 29, 2019 05:02 PM
zukinut
May 28, 2012 10:35 PM
brownfoot
May 3, 2010 01:54 AM
LotusJoe
Sep 23, 2009 11:58 PM
nick65f100
May 27, 2005 08:27 AM
