No Blinkers
Old May 27, 2012 | 08:24 PM
wyazel1's Avatar
wyazel1
No Blinkers
My truck has been sitting for a few months and today I finally got my new transmission in it and got it started/driving. All my lights work fine but I have no blinkers, nothing on the dash, front or rear. All the other lights are working fine. The blinkers were working fine when I parked the truck. Is there a fuse that could cause all the blinkers to stop working all of a sudden? Any other ideas? Thanks for any advice!
Old May 27, 2012 | 08:28 PM
montana_highboy's Avatar
montana_highboy
Are your hazards working? if so, swap the flashers around, if the blinkers work now, you found your problem.
Old May 27, 2012 | 08:58 PM
wyazel1's Avatar
wyazel1
The hazards never did work on this truck.
Old May 27, 2012 | 09:20 PM
ChiefM's Avatar
ChiefM
sounds like both flashers are bad, one is for blinkers, the other for hazard.
Old May 27, 2012 | 09:31 PM
wyazel1's Avatar
wyazel1
I am only able to locate one flasher, under the dash near the fuse block. Is this for the blinkers or the hazards? Where is the other flasher located??
Old May 27, 2012 | 09:41 PM
montana_highboy
Time to take a trip to NAPA, i suspect the flasher for your hazards is missing, and the flasher for your turn signals is faulty, 4 bucks and you're back in business.
Old May 27, 2012 | 10:29 PM
wyazel1's Avatar
wyazel1
I was messing around and figured out that if I hold the hazard switch on the column, the blinkers work. Just a small amount of pressure of the 'HAZARD' switch on the column makes the blinkers work. WTF!! LOL.
I wedged a small piece of a zip tie in the hazard switch and the blinkers work great. Does this make any sense to anyone???
I am wanting to start driving the truck again but I'd like to have blinkers, I really dont wanna rely on a piece of zip tie wedged in there lol......
Old Jun 22, 2012 | 08:41 PM
deerhuntertyler's Avatar
deerhuntertyler
I'm haveing the same problem with my 78 f250, and cant locate the flashers. where are they found?
Casey Hope
17
Mar 27, 2018 12:36 PM
SideWinder4.9l
Oct 1, 2014 07:50 AM
N V US Lawn Care
31
Feb 3, 2010 04:29 PM
kevin.ford-trucks
1997 - 2003 F150
Oct 15, 2007 02:51 PM
ms
Feb 23, 2001 06:56 AM
