ok guys i am having a really bad day. drain pan plug is striped, so i bought a new an gasket making kit and i got all the bolt loose and the damn pan wont drop this is pissing me off any ideas on how to get this durn thing down???? also i had the wheel off and how much should it turn? i got 4-5 turns with the tire on before it stoped on its own. withthe tires off i got maybe 2 .
I'm guessing based on previous experience on other motors, but I believe you need to remove the timing chain cover to drop the oil pan.
And I'm not sure what your looking for with the wheel turning part.
