Shock Absorbers.
Old May 27, 2012 | 06:31 PM
Texas Chain Ring's Avatar
Texas Chain Ring
Shock Absorbers.
Need to replace 'em. Don't tow anything, just want some equal to truck factory specs. Looking for recommendations.
'01 F250 SD 7.3 Powerstroke TD super cab.
Thanks.
Old May 27, 2012 | 07:05 PM
rcgtsport's Avatar
rcgtsport
i just put kyb mono max on my f350 cc drw and liking them. online $58 each.
Old May 27, 2012 | 09:01 PM
Texas Chain Ring
Are they noticeably different than what the truck came with? I was wondering if I should put those heavy duty load assist type shocks or just the regular replacements.
Thanks.
Old May 27, 2012 | 09:32 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Monroe Reflex. Look up which kind you need here:
http://www.monroe.com/
They will give you the numbers for your exact vehicle specs. Then you can search Amazon for an excellent price. I got 4 for my F-350 for $160.00. They wanted $500.00 installed locally. Good luck!
Old May 27, 2012 | 09:39 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
No towing?
No off road?
Bilstein 5100s or Rancho 5000s.
Old May 28, 2012 | 08:17 AM
Joe_914's Avatar
Joe_914
Bilstien the last shocks you will ever buy. not that much more than Monroecraptastic.
Old May 28, 2012 | 08:49 AM
helifixer's Avatar
helifixer
I get the bilsteins warrantied about once a year for leaking, about every second year I have to replace or repair a shock mount. this truck is mostly highway driven and driven nicely, about 10,000 miles a year.
in short I will never pay money for bilstein shocks again.
Old May 28, 2012 | 08:59 AM
Joe_914's Avatar
Joe_914
I think any shock will leak if they get bottomed out. (looking at your avatar)
One thing to be aware of is some our trucks are not lifted and the standard F250 shock from Bilstien is to long.
Warrantee is good and they do stand behind them no matter what we do to them.
Old May 28, 2012 | 09:22 AM
CampSpringsJohn's Avatar
CampSpringsJohn
If I were towing or hauling some heavy weight, I would want something stiffer than the monroematics. I have those on my 02, as I don't do either of those very much. Bilsteins are on my 97 work truck. A very good stiff shock. Don't know that I would want them on a daily driver if I wanted a smoother ride. I have monroe magnums on my 99 work truck. I think the Bilsteins would be better for it though. Curious about the Rancho's though. I will likely give them a try on my next shock purchase.
Old May 28, 2012 | 09:26 AM
Joe_914's Avatar
Joe_914
Shocks do not support more wieght.
Shocks dampen springs.
Carry big loads get stiffer springs or air bags
In my opinion Bilstien is the best bang for the buck for our trucks. If I coudl get Konis I would but 400 bucks a corner for a street driven truck is silly.
Old May 28, 2012 | 10:03 AM
maevans's Avatar
maevans
IMO - Bilstien 5100 are over priced pieces of JUNK.
Old May 28, 2012 | 10:10 AM
smithrock's Avatar
smithrock
I went with ProComps in front, because I level lifted my front end and they had the correct application for my rig. Happy with them so far!
Old May 28, 2012 | 10:11 AM
CampSpringsJohn
I know shocks don't support the load. What I was referring to was a heavily loaded truck and/or trailer would benefit more with a stiff shock over a mild resistance shock. Different shocks for different applications. Also, what one person likes may vary greatly for another person even on the same application.
Old May 28, 2012 | 10:12 AM
mechelement's Avatar
mechelement
Bilstiens (the yellow ones) have been outstanding for me.
I wouldn't put ProCRAP on anything after running them in my Jeep once. Garbage.
Old May 28, 2012 | 10:18 AM
Joe_914's Avatar
Joe_914
I real nice shock for not a lot of money is AFCO
Yeah the circle track shock. I had them on my 914 pictured in the avatar. Drove it on the street as well as the autocross and road race courses. Damn fine shock. you can get them on ebay for cheap in any sort of valving you think you might need. and they come in all different lengths so figure out what you want and start searching.
