2004 ford f-150 I replaced my stater with a new one but I still have issues. When I try to start it's very hard and the gauges go haywire untill the engine smooths out. Sometimes I get a clicking sound.
X2 on the battery. Get a load test run on the battery. Remember, a battery can last anywhere from 6 months to 10 years. Average battery life is 4-5 years.
Thanks Greg B I got a new battery so that is fixed now when I turn on the AC my idle goes up then way down. When I got the battery from Sears they said I had alternator blockage. I think it' probably the alternator but I can't figure out how to get off the serpertine belt.
You need to move the tensioner pulley, its spring loaded. Put a socket on it and turn it to release the tension on the belt. Remove belt. install new belt. Release pressure on tensioner pulley and install the belt.
