Pyro gauge
Old May 26, 2012 | 11:41 AM
hondarider10's Avatar
hondarider10
Pyro gauge
I just installed a pyro in my 93 7.3 na.I put the probe in the y pipe.In 4 gear running 2500 rpm it gets up to about 850 with no load.I was wondering if this is normal if not what is the normal exhaust temp???
Old May 26, 2012 | 12:02 PM
akamacgyver's Avatar
akamacgyver
Clueless spectator!
I don't know about normal, but location of the probe can make a big difference. I know I hit over 1000 when pushing my turboed 93 uphill with my fifth wheel regularly without problems. I believe you are O.K. up to about 1100 degrees, before you can start cooking piston soup! Do you have a coolant temp gauge, or are you using the dash gauge? If your coolant temp isn't running high then I would think 850 is not a problem.
Old May 26, 2012 | 04:38 PM
monte97z's Avatar
monte97z
Just mounted mine like 2 weeks ago. I'm in the manifold pretty much in front of #6. Empty and 3/4 throttle from a stop ill hit 1000 by the time I take my foot out of it at 65. Haven seen over 1150 yet. Crusing @ 60 empty I'm like 350. BTW that's 6.9 with c6 and 3.55 rear.
3000gtman
Dec 19, 2016 10:08 PM
EASTSIDEAUTO
Mar 11, 2012 10:12 AM
tjbeggs
18
Aug 31, 2007 01:43 PM
brelandt
Bronco II
Jul 13, 2006 09:03 PM
firedudecndn
Aug 17, 2005 05:06 PM
