4” mbrp exhaust
Old May 26, 2012 | 09:32 PM
cory5517's Avatar
cory5517
Smithrock did your exhaust come with a tip?
Old May 26, 2012 | 09:42 PM
smithrock's Avatar
smithrock
No. Not sure if I'm gonna put one on yet
Old May 26, 2012 | 10:07 PM
cory5517's Avatar
cory5517
Mine came with a 5” tip. Mine will probably sit a little lower with the tip
Old May 26, 2012 | 10:55 PM
schlepprock250's Avatar
schlepprock250
I have a 5" tip on mine,the tip rests about an inch below the body,just enough so it don't hit ,while the tip is an inch below the body the arch is straight up and down over the rear axle. Mine is a Magnaflow and not an MBRP but I would think the bends would be the same,looking at your pic,the top of the arch over the rear axle will be more towards the passenger side,if so just loosen the clamp that holds the last section and rotate the pipe towards the drivers side which will in turn cause the tip to rise..
Old May 27, 2012 | 01:38 AM
big poppa's Avatar
big poppa
Disregard the date, was off by years but this is what mine looked like before I adjusted them a bit, just a bit of tweeking, thats all it takes. I don't have any after pics but the angles are the same.
Old May 27, 2012 | 06:57 PM
cory5517's Avatar
cory5517
cory5517's Avatar
cory5517
Much better
Old May 27, 2012 | 08:34 PM
schlepprock250
LOL..Yep much better..
Old May 27, 2012 | 08:38 PM
cory5517's Avatar
cory5517
I may see about raising it out more tomorrow
Old May 27, 2012 | 09:07 PM
smithrock's Avatar
smithrock
I'd go little more if you can
Old May 27, 2012 | 10:35 PM
jdw1's Avatar
jdw1
So i am looking at exhaust systems for my 02 in sig, i want the pipe to come out from under the body at the same angle as the oem exhaust, almost at a right angle to the body, so the question is does anybody make a 4" exhaust that looks like the oem pipe angle under the rear fender, i dont want a pipe that comes out from under the body at about a 45 degree angle.
So far i have looked at MBRP and Diamond Eye systems but it kinda hard to see the exit angle.
Any help or pics of exit pipe would be great!
Thanks
Old May 27, 2012 | 10:51 PM
smithrock's Avatar
smithrock
Look on page one. I posted some pics of mine. Angle is all what you pretty much want it to be. I have the MBRP
Old May 28, 2012 | 12:44 AM
  #28
jdw1's Avatar
jdw1
That looks like a 45 to me, maybe i'am missing something
Old May 28, 2012 | 07:12 AM
  #29
cory5517's Avatar
cory5517
I see 4” all the time that look like they exit like a stock exhaust. Next time I see one I'll stop them and ask what kind of exhaust they have.
Old May 28, 2012 | 09:35 AM
  #30
locknload223's Avatar
locknload223
My 4" MBRP w/ 5"tip. I took some time adjusting it at the axle to get it right, a little there goes a long way a the tip. I wanted my tip high and tight, it's about an inch from the body and I made sure the body's paint wasn't getting hot at all.
