2003 horn problem
Old 05-25-2012, 02:17 PM
crashdummy38's Avatar
crashdummy38
crashdummy38 is offline
2003 horn problem
My horn has quit !
cruise control is still operational, fuses and relay for horn are good
(substituted known good ones)
Have dual horns with one white and one black wire feeding both.
Before applying power here to test the horns themselves,
Can I assume that the black is ground and the white is hot ????
Any help would be appreciated
Thank you and have a GREAT day !
Old 05-26-2012, 12:55 PM
crashdummy38
Well, my 74 yr old eyes "aint what they used to be"!
After dusting off the "white wire" I see that it is the yellow/green stripe that now makes sense as the hot lead.
Applied 12v and ground and found that the horn assembly is good.
If no one any ideas of what to look at next, guess Ill just purchase and install a horn kit with a button in the dash.
Have a GREAT DAY!
Jghake
08-31-2018 07:25 PM
oft
13
10-17-2014 08:18 PM
centralNH
05-17-2014 11:37 AM
FordRun
18
09-19-2012 08:33 PM
gtex
08-21-2001 08:11 PM
Quick Reply: 2003 horn problem
