paint help
Old May 26, 2012 | 08:23 AM
carnut122's Avatar
carnut122
Originally Posted by ZOOT
I read your post again.... do the the body filler (bondo) before the urethane primer. Rough up the area you're gonna fill for good adhesion.
I agree and I agree with the other guy who said the second coat of epoxy is overkill. If anything, I'd do a second coat of the high build urethane oven any of your bodywork that was done after the last coat of high build urethane. BTW, that high build urethane was almost too thick to spray out of my primer gun.
Old May 26, 2012 | 11:31 AM
AXracer's Avatar
AXracer
Sherwin Williams makes a DTM cyanate free primer that you can mix with one of two different hardners. One makes it a sprayable high build primer, the other thickens it to a squeegieable surfacer putty. An interesting product, doesn't need an underprimer, can be used to touch up any sand thru, doesn't need an overcoat of primer to even the color, all with one product.
Some manufacturer's now recommend applying their high build primers with a foam roller rather than spraying it. Download the manufacturer's instruction sheet for the product for application information.
Keep up with your favorite manufacturer's new and reformulated products you may get a pleasant surprise!
Old May 26, 2012 | 12:48 PM
needhelp49's Avatar
needhelp49
one thing i didn't read was clean everything with wax and grease remover at every stage including before you start your first sanding. if you sand on a dirty panel all you do is grind that dirt grease and stuff into the metal and it will show up in the final product. as a amateur i like spraying bc cc the base sprays easy and you can sand out most problems that come up in clear.
Old May 27, 2012 | 02:17 AM
Ravenheart's Avatar
Ravenheart
No input to add, but some good paint tips to follow.
nlareau
Paint & Bodywork
Jul 12, 2011 07:08 AM
63' f100
Paint & Bodywork
16
Apr 3, 2011 01:59 AM
Rancho*Ryda
Paint & Bodywork
Jun 13, 2005 07:08 PM
bob-63-292
Paint & Bodywork
Nov 2, 2003 10:42 PM
jwtaylor
Paint & Bodywork
Aug 12, 2003 08:13 PM
