2wd frt spacer
Old May 23, 2012 | 08:39 PM
rocky71's Avatar
rocky71
2wd frt spacer
in order to lift my 86 f250 2wd to me it looks like its best to loose big centering bolt assembly in lower control arm and install a half to one inch shim. This is at the bottom of the coil spring. Is the way to lift my frt end??? or what?
Old May 24, 2012 | 03:10 PM
Franklin2's Avatar
Franklin2
Your frontend has the same geometry as the 4wd units. Any lifting throws it out of alignment, and if you go too far, the shop can't get it back in. You may be able to put a 1 inch spacer in there, and then get it aligned and be ok. I don't know if you could use a 4wd kit or not, and lift it 4 inches with the dropped brackets, pitman arm, etc.
Old May 24, 2012 | 04:33 PM
snyper438's Avatar
snyper438
I lifted an 83 E150 van using an F150 kit with no problems. The kit came with all the brackets needed (A-arm, TTB center mounts and pitman arm) 4 inches later she was on 33's.
Old May 25, 2012 | 04:07 PM
rocky71's Avatar
rocky71
today i took out coil spring and its "perch"...makes cence to me now, i will order mr gsk spacer one inch from summit race $13 ea.....thx
mark460
16
Jan 19, 2018 07:50 PM
mark460
Jun 2, 2016 03:06 PM
my91stealth
Dec 2, 2010 02:55 PM
marioc956
Offroad & 4x4
19
Dec 6, 2006 02:36 PM
Motown Fire
Feb 8, 2006 12:22 AM
