Linkage Stinkage
Old May 23, 2012 | 07:44 PM
topfuel's Avatar
topfuel
Linkage Stinkage
OK I am dropping in the 302 in the place of the six, I am trying to hook up the three speed linkage , and there is a little stud with a plastic ball that threads in to the block that hooks to the Z bar linkage. What is this part called? and where can I get one that has the correct thread to work with this 302?
Old May 23, 2012 | 09:05 PM
66f-100's Avatar
66f-100
It is called an engine side equalizer bar mount. They list new ones in the mustang catalogs. Whether or not that would work in your application, I don't know. I'm sure someone else will chime in with the answer.
Old May 23, 2012 | 09:59 PM
66f-100's Avatar
66f-100
Just checked my NPD truck catalog. They have it listed for 69-79 302. Part# F-7A535-1, cost $14.95. They also have the plastic ball. You can view their catalog online.
Old May 23, 2012 | 10:17 PM
topfuel's Avatar
topfuel
Thanks guys. you have been very helpful with it build.
Old May 24, 2012 | 01:12 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
302 pivot will not work on a 240/300 bellhousing, wrong thread size.
240/300 original: C5TZ-7A535-A .. Clutch Pivot / 2.54" long / 1/2" -13 thread.
1969/79 F100/150 & 1969/74 Econoline 302: C8UZ-7A535-A .. Clutch Pivot / 2.54" long / 9/16" -12 thread.
The two plastic bushings are available from Ford C1AA-7543-A / Takes one on either side of the equalizer bar.
1969/79 F100/150 302 also uses a different clutch equalizer bar and frame pivot than 1965/79 F100/350 2WD 240/300 & 1965/76 F100/250 2WD & F350 352/360/390.
Old May 24, 2012 | 05:59 PM
topfuel's Avatar
topfuel
Will the 302 pivot work with the 240 equalizer bar?
Papa'sPride
Feb 3, 2018 05:09 PM
7379ford
Sep 21, 2017 05:49 PM
juchertf100
Jan 10, 2007 12:31 PM
blatherskite
Oct 6, 2005 02:50 PM
