Charging issue help needed
Old May 23, 2012 | 12:08 AM
droppedf100's Avatar
droppedf100
95 F150 2wd with a carbed 460 swaped into it. Has the stock serpentine brackets and alternator set up from a mid 90s F250 and the stock alternator harness. New battery, rebuilt alternator that was checked at 2 Autozones and 1 Advance auto. Tried a known working alt harness from another truck but the battery light is still on and it shows very low voltage. I have a multimeter and it seems to be getting power with the key from the green/red wire all the way to the alt but it only puts out the same voltage as the battery which is 11.5v. Im not the best with trouble shooting so tell me what to check and how to check it please so I can get this thing back on the road
And I did search but couldn't come up with a solution. It worked fine before than intermittently had issues and now its completely undriveable.
Old May 23, 2012 | 08:42 AM
rla2005's Avatar
rla2005
Please verify which alternator you now have in the truck a 2G or 3g. Your 1995 most likely had a 3G. The older 1990 engine came with the POS 2G, aka fire hazard. If you have the 2G in there you are missing some wiring to make it work. Do yourself a favor, if you are running a 2G, get a 3G and be done with it.
Old May 23, 2012 | 04:17 PM
droppedf100
It is a 3g stock replacement for a 95 F250. The lower amp of the 2 so 95amp I guess.
Old May 23, 2012 | 10:59 PM
rla2005's Avatar
rla2005
Okay, now I understand your setup. You already verified the green/red wires is hot with the key on.
Ryan @ oldfuelinjection.com has some good info on wiring up 3G alternators. Here is a link to the info for many different versions: Fuel Injection Technical Library » Alternator Files
This photo here might help you out too:
There should be an inline fuse for the charge wire to the battery, perhaps the fuse is blown?
Old May 24, 2012 | 08:12 PM
droppedf100
OK I checked all the wires in the harness for continuity with a multimeter and all tested good. Fusible links checked good. Checked all fuses in both the under hood and under dash fuse boxes. Shows 11.6v from the green/red wire from the harness to the alternator with the key on. Took it to the parts store and had it checked while I watched and tested it myself while on the machine with my multimeter and it put out 15.1v. Back on truck 11.6-11.7v. Than I ran i jumper wire straight from the battery to the energizing post on the alt and still 11.6. Im completely stumped.
The battery light does not come on with the key or while its running. I have no clue if that is related.
Old May 24, 2012 | 09:50 PM
rla2005's Avatar
rla2005
There is not much wiring to these 3G alternators. Here is a wiring diagram from Ryan:
You are missing something simple here.....which are the toughest to find.
Old May 25, 2012 | 12:07 AM
F150xlt's Avatar
F150xlt
If the posted diagram is correct, you should measure 12 volts at all times on
the Yellow/White wire.
The dash charge indicator should light when you turn the ignition on.
The voltage regulator provides the ground path to turn the bulb on.
Since you swapped the engines, make sure you have a good ground
from the engine to the negative battery cable because the engine
is the ground path for the alternator.
Old May 25, 2012 | 05:16 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Not really.
The yellow/white wire (alternator output) should be ~14.3V engine running.
You can't 'charge' a 12V battery with 12V.
A 12V battery should show over 13.5V engine on, and about 12.5V at rest.
Yes, the charge indicator bulb provides current to excite the alternator.
That is why the bulb lights, voltage differential across the filament.
But there should be a resistor in parallel to the bulb (on the foil circuit board) to provide current if the bulb burns out.
Old May 25, 2012 | 07:25 AM
jroehl's Avatar
jroehl
Originally Posted by ArdWrknTrk
Not really.
^^^This. If you're only measuring 11.5V with the key on, engine off, you've got a dead battery. Put it on a charger overnight, then measure the voltage between adjacent cells--pop off the vent caps (usually 2-6 of them), and just stick the probes of the voltmeter down into the acid (don't get the acid on you). Adjacent cells should measure about 2.1V (which would give you 12.6V for the whole battery). If you get 0.0V between two adjacent cells, then you've got a short in the battery.
Jason
Old May 25, 2012 | 09:01 AM
F150xlt's Avatar
F150xlt
Not really.
The yellow/White wire (alternator output) should be ~14.3V engine running.
The Yellow/White wire is the sense voltage for the regulator. If there is no
sense voltage to the alternator regulator, what will be the voltage be at
the alternator battery terminal post?
The original poster did not mention what voltage is on the Yellow/White wire
at the regulator plug end.
Of course it should always read what ever the battery voltage is since it's
connected to the positive terminal of the battery if it's wired like the
posted diagram.
Old Jun 29, 2012 | 10:17 PM
droppedf100
Ok I finally figured this out. After swapping batteries from another running truck, swapping alt harnesses from another running truck and finally having the alt converted to be self energizing (1 wire) with no luck it ended up being a ground issue like F150xlt said. It has a good ground from the battery to the frame, block and fender and a ground from the firewall to the intake bolt but it still wasn't grounding the alt. Had it running with the multimeter and ran a wire from the neg to the alt body and boom 14 volts So I ran a wire from the alt body to the block and all is good. It should ground through the bracket but my theory is the bracket is powdercoated and possibly not grounding like it should. Put 100 or so miles on it with zero issues. Thanks for the help. Sucks it took so damn long haha
Bubba Jones
1978 - 1996 Big Bronco
Sep 17, 2012 12:25 PM
mck99f250
Jun 15, 2011 07:38 PM
rob-o
Jan 29, 2009 08:32 PM
storm96
Electrical Systems/Wiring
Nov 13, 2008 10:27 PM
BENG0924
Jan 22, 2008 01:32 PM
