I've been looking at buying a visor because they look sweet. I can't find any that aren't white or unpainted. Anyone know if you can get them painted the color of your truck or just buy a black one? I also have lights on top of my cab so idk what to do about that. Move them to the visor?
They only come in gelcoat white, some distributors used to offer paint services such as DriverFX. However, it will cost about the same as getting your local paint shop to paint it and if you need to tweak it during installation you will have better timing.
The best way to do these is to install it still in the white, and check the door fitment. Make any alterations needed (they typically need a little trimming to clear the door.) Take it off and carry it to the painter, when he's done reinstall it and life is good.
There are going to be three holes under each lamp. I wouldn't move them unless you had to. I believe lund industies listed if the visors interfered with the factory lamps. If you have aftermarket then it will be a trial and error.
As far as lighted visor go, lund has two style, moon and lunar. The lunar style is smoother while the moon is blockier. Then the Solar and Sun are not lighted.
