Dana 60 Front end
Old May 22, 2012 | 05:57 PM
Second79F250's Avatar
Second79F250
Dana 60 Front end
I am looking at putting a dana 60 front and in my 79 f250. I have heard all kind of terms like King pin, high pinion, closed knuckle, reverse gear, ect. ect. I am just looking for some info on the best one to drop in and if you have any pictures if you can show me what the heack I am looking for. I am just smart enough to know a d60 when I am looking at one but form there I would love some help.
Thanks All!
Old May 22, 2012 | 06:13 PM
montana_highboy's Avatar
montana_highboy
You want a 78/79 D60, they'll all be high pinion, reverse cut, king pin, open knuckle, disc brake axles.
They can be found in all '79 F350 4x4's and 78/79 F250 4x4's that were equipped with the "Sno-Fighter" package.
These 78/79 D60 axles are a direct bolt-in swap, later D60's will require major fabrication to fit your application.
Expect to pay anywhere from $800-$1,200 depending on condition and location.
Old May 22, 2012 | 08:34 PM
tabascom16's Avatar
tabascom16
King pin knuckles will have 4 bolts in a square pattern holding a cap that sort of looks like a little top hat on top of the upper knuckle vs a ball joint that will have one big nut holding it on.
An open knuckle is a steering knuckle where you can see the U-joint axle. Closed knuckles you cannot see the ujoint. It looks like a closed ball and socket joint. These went by the wayside along with drum brakes on the front.
Reverse cut gears just mean they are cut in a mirror image vs standard gears. This allows the pinion on the later dana 60s to be a high pinion. High pinion means the center line of the pinion is above the center line of the axle/axle tubes which will keep it out of more danger off road.
Old May 22, 2012 | 09:09 PM
mark a.'s Avatar
mark a.
This is what you need.
Old May 22, 2012 | 09:14 PM
mark a.'s Avatar
mark a.
Front
Old May 22, 2012 | 09:32 PM
Stinky7-11's Avatar
Stinky7-11
Tisk, Tisk, Tisk
Old May 22, 2012 | 11:22 PM
montana_highboy
Maybe Stinky will sell you his 60
Old May 23, 2012 | 12:36 AM
Stinky7-11's Avatar
Stinky7-11
When you give me them Slots!
Old May 23, 2012 | 12:38 AM
montana_highboy
I'd make that deal!
Old May 23, 2012 | 12:55 AM
Stinky7-11's Avatar
Stinky7-11
I'd make that deal!
Now what would you do with another!
Old May 23, 2012 | 10:14 AM
Second79F250
Great Thanks Folks Now I just need to find one.
Old May 23, 2012 | 11:37 AM
montana_highboy
I sold my D60 this past winter to generate some cash flow, i finally came to the realization that i "wanted" it more than i actually "needed" it, so it found a happy home.
Old May 23, 2012 | 01:57 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Here is some reading for you to get D60 smart....
Pirate4x4.Com - Extreme Four Wheel Drive
I have 2 front D60's axles and a set of slotted mags setting around, oh lucky me.....lol.
Old Jun 5, 2012 | 10:03 PM
rsfabrication's Avatar
rsfabrication
<a href="http://www.pirate4x4.com/tech/billavista/%3Cacronym%20title=%22Page%20Ranking%22%3E%3Cacron ym%20title=" page="" ranking"="">PR-Kingpin/index.html" target="_blank">Pirate4x4.Com - Extreme Four Wheel Drive
That link is dead btw.
Old Jun 5, 2012 | 10:38 PM
Stinky7-11's Avatar
Stinky7-11
Try these!
1. Pirate4x4.Com - Extreme Four Wheel Drive
2. http://www.pirate4x4.com/tech/billav...pin/index.html
cooperstown24
15
Jan 14, 2019 02:18 PM
51MHF5
Jul 7, 2013 02:39 PM
fordinmudd
Offroad & 4x4
20
Oct 25, 2006 04:12 PM
1ole4d
Jul 20, 2002 09:21 PM
Steve_Uzi
Feb 4, 2001 01:08 PM
