driveshaft help?
Old May 22, 2012 | 05:36 PM
LILhorny7.3-6spd's Avatar
LILhorny7.3-6spd
driveshaft help?
so i put hd leafs in the front it went from 2 leafs to a thick tripple stack equals out to be 3inch lift so the rear i took the 2inch blocks out and put in a 5inch block for now anyways just to level it out now when i take off i have a vibe coming from my driveshaft and at higher speeds also idk what the hell i can do to loose that viberation in the shaft its got the dual shaft with center bearing any ideas?
Old May 22, 2012 | 06:03 PM
BigAlsPSD's Avatar
BigAlsPSD
Usually you have to shim the center support bearing down about 1/4" for each 1" of lift, that's where I would start.
Old May 22, 2012 | 08:09 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
There are several threads here concerning your issue if you do a search. Good luck!
Piston Honda
Sep 1, 2014 01:52 PM
Bigtruc
Jan 3, 2013 07:41 AM
LawF250
Offroad & 4x4
Aug 17, 2010 01:44 AM
dave91gt
Oct 1, 2009 11:59 AM
tony338um
Jan 6, 2005 11:11 AM
