Cab for an '89
Old May 22, 2012 | 01:29 PM
ytlogger's Avatar
ytlogger
Cab for an '89
My lovely '89 F-250 supercab was involved in an accident and depending how the quotes shake out I may be looking to replace the cab. Any of you Ford guru's tell me what year of cab is compatible with mine?
Old May 22, 2012 | 01:39 PM
johnboggs21's Avatar
johnboggs21
83 up to 97 I do believe
Old May 22, 2012 | 03:51 PM
86f250XLT-4x4's Avatar
86f250XLT-4x4
Actually I believe it's 81-97 I know I had no issue with the 89 doors going on my 86 also had borrowed doors from my buddy's 81 and they worked fine
Old May 22, 2012 | 07:37 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Note:
80-86 cabs have the seat belt retractor up by your head, while 1987-1997 have it by the floor.
1980-86 cabs do not have a factory punched hole for the hydraulic clutch master.
And 1992-97 cabs, the firewall is slightly different where the brake booster and clutch master mount.
Old May 22, 2012 | 10:38 PM
oldblue89's Avatar
oldblue89
Originally Posted by IDIDieselJohn
Note:
Good call on the seatbelts, I didn't even notice...
What do you mean by them not having "a factory punched hole for the hydraulic clutch master" cylinder? I have an 86 cab and chassis F-350 4x4 with the T-19 4 speed. It has a hydraulic clutch master cylinder in the same place my 89 F-250 idi 4x4 with a zf5 does.
Only reason I'm curious is that I might do a cab swap (from either a 1990 or a 1994 truck). What exactly would the difference be with regard to that master cylinder? I suppose by then I might just swap a zf5 in anyway... those 4 gears with 4.10 gears and dual wheels don't do too well on the highway...
Old May 22, 2012 | 10:54 PM
RacinNdrummin's Avatar
RacinNdrummin
87-91 is the only cabs that are a direct swap. The harness holes in the firewall are different between the 80-86, 87-91, and 92-97... As mentioned above, the seat belt locations are all different between the years, this matters if you plan to keep your interior panels. The mid-88+ cabs have the provision for the T-case shifter in the floorboard instead of the tranny plate.
Anyway, there is lots of little stuff that will hang you up, your best off to search for the right style cab for your swap.
Old May 23, 2012 | 08:22 PM
IDIDieselJohn
The automatic trucks 1987+ have a pre-punched hole in the firewall with a plate for the clutch cylinder, while older trucks have no pre-punched hole.
Old May 28, 2012 | 10:29 PM
RacinNdrummin
Almost... My 88 or 89 didnt have the punched hole... I think those were the trickling out years for that though...
Old Jun 11, 2012 | 12:33 PM
bc4x4f250's Avatar
bc4x4f250
Yes, I'm a day late and a dollar short...
Question: While certainly easy enough to swap out a cab, how are you going to deal with the VIN tag on the cab?
In other words, will your state DMV/ law enforcement have no issues with the new VIN number? Or, do you think they will overlook it if you change out the VIN number from new to old (which, in CA, is an absolute no-no)?
Just wondering...
Old Jun 11, 2012 | 01:25 PM
johnboggs21
Just wondering...
As far as I know, swapping VIN tags in any state is a felony. I am doing a cab swap on my truck, and asked a police officer what I should do about the vin being wrong. He said I have to take the title for my truck, and the title from the truck that the cab came off of up to the DMV and explain the situation. He said they should be able to make me a new title with the correct information.
Old Jun 14, 2012 | 10:03 PM
mlouritt's Avatar
mlouritt
I have a swapped cab on my truck. I needed the original title to the original truck, and the original paperwork for the replacement cab, no copies for any of the paperwork were allowed. After many trips to the DMV and a State Patrol inspection, I was issued a "Reassembled Vehicle" title and a state issued VIN number.
Cdn4X4
Dec 9, 2012 08:44 AM
nickelndime79
Oct 25, 2012 01:04 PM
Ohio Ford Farm
Feb 24, 2007 10:14 PM
sheltrow
Jan 31, 2007 09:25 PM
