1989 F150 4.9 surging
Hi,
My 89 F150 has what appears to be a fuel surge issue. Upon cold start, it races, almost dies, races, almost dies... until warmed up. Until recently, it ran fine once warmed up. Now, I'm getting a surge when driving but only some times. I bought it last year from the original owner with only 55,000 miles on it and replaced the fuel pump relay (he was taking off the ground cable when not using it to keep it from running). I'm a little stumped and would welcome some sage advise before I start replacing parts not knowing if they need replacement.
Thanks, Mike
Thanks, Mike
Surging idle can have many causes. Most common are sticking/faulty IAC, vacuum leak(s), faulty TPS. I would start by inspecting the IAC. If it is gummed up with carbon you can try cleaning it. If you have to replace it use a Ford/Motorcraft brand. Many of the aftermarket brands have less than stellar quality control.
Hi,
Thanks, Mike
Thanks, Mike
This might be of some help to you
Click this link:A9x ECM's (and same years ECM's) Failures Due to Age
Good luck on your quest.
Bob
had this happen once to myself a mechanic freind of mine showed me this trick so before you spend money on sensors not saying you wont need to but try this trick first take your intake hoses off spray brake clean on the butterflys take rags and clean them and the interior housing the best you can next open butter flys and clean the back side of them the best you can cured my problem instantly actually made it a routine maintence Note do not do this with motor running and i hope it helps save ya a buck or 2
6 years later......
Good read in this thread from another forum: Random Idle Surge When Warmed Up - Ford Bronco Forum
I have stated many times the most common cause(s) of a rolling idle are:
Sticking/Faulty IAC
Vacuum leak(s)
Worn throttlebody
bad TPS
sticking throttle cable
In the thread I posted the OP had almost every single one of those that all contributed to the rolling idle issue.
92 Red F150
05-17-2004 07:17 AM
92 Red F150
05-14-2004 11:00 AM
