Coolant Puke
Old May 21, 2012 | 11:13 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Coolant Puke
So my engine (presumably the waterpump, but I didnt chase it down specifically, however it was on the front of the motor) decided to puke about 1/2 quart of coolant while I was picking up breakfast between jobs this morning. Come back out to see a steady fast drip and a large puddle under my truck. I tried to find the source but couldnt in the parking lot. The whole axle and front steering was covered. I released the pressure in the bottle and started it up and it hasnt leaked a drop sense.
Is it time for a water pump?
Old May 21, 2012 | 11:21 PM
Bonanza35's Avatar
Bonanza35
That would be my guess, but you really have to look it over. Clean it up, put the cap back on and let it idle till its warmed up. You should be able to tell then.
Chet
Old May 21, 2012 | 11:26 PM
smithrock's Avatar
smithrock
I'd say water pump too. I had one go out on another vehicle-same symptoms as you. Can you pressure test it?
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Chet
I put the cap on, and drove 80 miles (throughout the day). It puked around 9 am and didnt dip one drop from then till now.
Old May 21, 2012 | 11:57 PM
big poppa's Avatar
big poppa
Maybe a stuck thermostat in that instance. When's the last time you did a T-stat change??
Old May 22, 2012 | 12:00 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
about 10,000 miles ago. Replaced with OEM motocraft. Also replaced the housing, and it wasnt that. I did pop the hood and look around and verified that the TS was dry amongst other things.
Old May 22, 2012 | 12:28 AM
big poppa's Avatar
big poppa
Hum, guess that rules that out. While you do look for the cause depending on your mileage, I'd defintly consider a waterpump change like the guys mentioned. I changed mine out around 160,...ish because of slight fluid weeping from the weep hole.
Old May 22, 2012 | 12:39 AM
Bonanza35's Avatar
Bonanza35
It wasn't the oil cooler was it?
Chet
Old May 22, 2012 | 12:43 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Chet
Doubtful. The crank shaft pully was wet
Old May 22, 2012 | 01:17 AM
Stewart_H's Avatar
Stewart_H
Isn't that a new pump? I thought you just changed it when you switched to ELC.
Stewart
Old May 22, 2012 | 10:25 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Stewart
No I couldnt get the fan off.
Old May 22, 2012 | 10:51 AM
ToMang07's Avatar
ToMang07
Did you ever sell the pump you bought Trey?
Old May 22, 2012 | 10:55 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Yes
Old May 22, 2012 | 11:04 AM
ToMang07's Avatar
ToMang07
No bueno.
Old May 22, 2012 | 11:15 AM
CSIPSD's Avatar
CSIPSD
Pump time... Just a matter of time before it pukes again and for good.
