Coil and Ign. Mod. Help?!!
Old Dec 11, 2011 | 08:26 PM
cgi2099's Avatar
cgi2099
I have a 81 f150 4x4 wit a 351M and a C6
Today i bought an Accel 8140 coil for my truck and a new BWD Ignition module. My question is can i just hook this coil up and new ignition module up, or is there something else i need to do? I put new BWD wires on last week and new Autolite AP25 plugs. I've been reading a little and have read something about a resistor being needed before the coil?
Here are links to what i bought:
Buy Accel Super Stock Points Coil 8140 at Advance Auto Parts
Buy BWD Ignition Control Module CBE7Z at Advance Auto Parts
Thank You,
Josh
Old Dec 12, 2011 | 09:23 AM
JimsRebel's Avatar
JimsRebel
Thank You,
Josh
Primary resistance is 1.4 ohms and secondary resistance is 9.2 kilo ohms
Coil should be fine as a direct replacement.
I would have just painted my old one yellow
Old Dec 12, 2011 | 09:29 AM
cgi2099's Avatar
cgi2099
LMAO the reason I got it is because I think something is wrong with my ignition system, when I get on the gas the truck cuts out like its flooding, so I was thinking Maybe I'm not getting enough spark. Also you wouldn't happen to know what I should gap the plugs at with the new coil, and wouldn't happen to know the stock voltage on the factory coil would you?
Old Dec 12, 2011 | 09:37 AM
JimsRebel's Avatar
JimsRebel
I would start with a normal plug gap as the coil is not really much different then a stock coil,
If it runs good with a normal gap, try opening it up .005 and see if it still starts OK.
fordboy300
Sep 22, 2013 08:42 AM
abe
Jan 1, 2013 04:51 PM
Jrock909
Aug 12, 2006 03:18 PM
Fine250
15
Sep 11, 2005 01:06 AM
Enterprizer
May 27, 2005 02:03 PM
