Pulling to right when braking
Old May 21, 2012 | 07:06 PM
hamiltonfighter's Avatar
hamiltonfighter
When I brake the Ex pulls really hard to the right. In your experiences, is this most likely worn brake equipment?
What suggestions do you have?
Old May 21, 2012 | 10:03 PM
Swagtastic's Avatar
Swagtastic
One (or both) of your calipers is/are siezing up. You need new calipers and a brake fluid flush definately, new pads probably, and new rotors maybe. If you can remember before this happened, whenever you came to a stop (especially at higher speeds) did you ever feel a vibration in the steering wheel? If so then the caliper has been at least a little stuck for a while and over heated your rotor and it became warped. Thats the maybe part. The good news is the caliper change on the Ex is SOOOO easy and you don't need to pay a mechanic to do it.
Old May 21, 2012 | 10:06 PM
Skip1970's Avatar
Skip1970
i hear the slides an brackets for the caliper are the main sorce of problem, and they are a real bugger to change out if they havent been addressed in a while.
Old May 21, 2012 | 10:23 PM
micromack's Avatar
micromack
It's pulling because equal pressure isn't being applied to both sides when you break. I would start by pulling the calipers off and greasing the slide pins. My guess is they're dry (if not seized in the caliper bracket) and at the least dirty. I'd pull them out, hit them with some break cleaning fluid, and use some fine sand paper to remove any dried on debri's or light rust. Then grease them real good and make sure they slide in and out freely with no binding. If they're in really bad shape, look at getting them replaced. They should be greased and slide in and out of the caliper bracket with little to no effort. Make sure when you re-install that you get the rubber boot up over the lip to keep out moisture and debris going forward. Good luck! Just did my breaks 2 days ago, all 4 boots on the front calipers were not seated in the lip on the caliper bracket, they were pretty gunked up.
Old May 21, 2012 | 10:36 PM
X-70STANG-F150's Avatar
X-70STANG-F150
... Also pull your pads and check the wear - they should be pretty even. If they're wedge shaped, then the slides aren't sliding or one of the pistons is sticking. If the pistons are working correctly, you should be able to retract them pretty easily with a c-clamp.
Old May 21, 2012 | 11:02 PM
hamiltonfighter
I just bought the EX a few days ago. Previous owner was't driving it much. Hopefully the caliper can be salvaged with these instructions.
Thanks everyone
nasmeyer
Escape & Escape Hybrid
Jun 23, 2019 02:55 PM
Blakshukvw
Dec 30, 2016 05:51 PM
Diesel 724
Oct 1, 2014 02:50 PM
crazyrwe
Nov 5, 2011 07:49 PM
Monsta
Nov 12, 2004 08:36 AM
