fog lights not working. need help???
Well at least you can have a drink. All I get are these
do to the meds for a back injury over 5.5 years ago
Well I could have a drink if I did not take the meds for a day
But then I would NEED the drink.
Sean
Sean
Unhook/pull the light blue/red trace wire out of the plug that's behind the passenger side kick panel.
05 f250 6 inch lift
Any chance I could talk you into a photos of how
your LED mod looks at dusk and night?
Please.......Thank You
I have the Amarillo edition and that dash is so dark
at dusk it's very hard to see till it gets full dark.
Sean
zhilton Thank You for that
Sean
Thanks to all who have helped me with this question. I just did the fog light mod an my fog lights are workin again.
Thanks to u all
Did you buy the 8000K already? If not buy 4300K or 5000K max. 8000k may looks good but will not provide better lights at night (something do do with human eyes can see best at 4300K...)
Yea. Fog light are on now. They r on with low an high beam.
I already had the 55w 8000k HID kit. Got it because it's the same as my headlights. Had to adjust my head lights down because I was blindin everyone with my low beams.
To all who helped me with this. I would give y'all reps. But I don't know how to. If someone will inform me on how to do it. I will give reps.
Click on that "heart" and you can give "Reps" And post a note to the poster!
My fog lights will not come on, can someone please help
I am also having problems with my OEM foglights coming on, all my fuses are good, my relay is working, i have new bulbs and a new switch. The light does come on when i pull it out for foglights. Does anyone have any ideas?
Whoa, certainly explains why you call her Big Kitty. That's a big cat.
Under the truck on the driver side at the frame head going through the wheel well you
should be able to find the foglight feed wires. Check and make sure that they are connected.
If you can't find it I can post a photo later on where you should be looking for the plug.
Sean <BR>
6.0L Tech Folder
Yes, on the switch itself. Thank you for looking into this for me, but I got it figured out. I was getting voltage at the pigtails, it didnt make sense the lights would not come on. Well I traced the wiring from the foglight relay and just outside the power distribution box I found the main power wire kinked and it had corrosion around it. I unkinked the wire and the wire itself was open, but was touching when kinked. Thats how I was seeing voltage, but once a load was put on it the amperage pushed the wire from contacting enough not to light up. I Enviro spliced it back together and everything works like a champ. I appreciate the effort.
