AIC wiring
Old May 20, 2012 | 03:21 PM
Piolet's Avatar
Piolet
AIC wiring
I was following the riffraff directions to install the isspro dimmer switch on my new gauges and I come to the line that says locate the auxiliary idle control (aic) connector and take power from the red wire with yellow trace.
I've located the aic, but mine has 3 wires, a blue/green a brown/white and a red/gray. I'm pretty sure I'm not color blind (don't think I am), but am I missing a 4th wire, or is the red/gray the one I want?
Full disclosure: electricial not my strong point so small bumps in the road like this for me can be game over . Any help appreciated.
Old May 20, 2012 | 03:34 PM
jmaskew's Avatar
jmaskew
I have pictures in my gallery from when I added gauges see if any of them help.
Edit: Look at the "Truck Pics" gallery.
Old May 20, 2012 | 03:59 PM
steelhead2's Avatar
steelhead2
Test the wire for power with a test light. Sounds like you switch just needs a power source.
Old May 20, 2012 | 09:38 PM
william_04_x's Avatar
william_04_x
Are you sure you're looking at 6.0 directions? AIC is typically a reference to 7.3 idle controllers.
Are you just trying to hook up a dimmer to gauges that are already installed?
Old May 20, 2012 | 09:55 PM
Piolet's Avatar
Piolet
Thanks for the help guys.
I have everything ready to connect and I called it quits for today.
Here's what I was going on http://www.riffraffdiesel.com/mm5/RE...ISSPRO_EV2.pdf
Jmaskew, I looked at your gallery (thank you) but it confirmed that I have a different wiring color than is in your pics and the riffraff pics it seems. Maybe it'll look better with fresh eyes tomorrow. But I'm confident I have identified the black box shown, and I have 3 wires. None of which are red/yellow.
William, I am putting in new gauges with a new dimmer all in one package. Reason I went with the extra dimmer was I read on the instructions that even with hooking up to the factory dimmer, they will never get fully reduced without it, and I do like a really dark cab when driving at night/early morning.
As mentioned in original post ... I have a lot to learn on wiring. Not my strong point, but I'll get there. Thanks for your help guys. Looking forward to getting these up and running.
Old May 21, 2012 | 06:13 PM
Piolet's Avatar
Piolet
Found the wire I was looking for. Maybe I was tired and needed the break. The lights on the gauges and the dimmer work correctly.
Thanks jmaskew for having the pics in your gallery. That was what I was looking for after all. Reps sent.
BadDogPSD
22
Feb 11, 2014 05:12 PM
maximusfd
18
Oct 29, 2013 07:35 PM
wbuffetjr1
May 25, 2011 11:21 AM
cobrarep
Sep 2, 2008 11:55 PM
mostroke
Jun 16, 2005 08:50 AM
