Autolite 4100
Old May 19, 2012 | 11:39 PM
PRIMERED79 SHORT BED's Avatar
Autolite 4100
Doing some research on the Autolite 4100 for a future mod.
Can i run a 4100 on a 4v manifold for a 400 motor?
Old May 19, 2012 | 11:51 PM
HIO Silver's Avatar
HIO Silver
yes. the 4100 is a square bore carb which will fit any manifold that can take a Holley 4150 pattern. Super easy to rebuild.
They typically come with 1.08 or 1.12 stamped in the clockface... the former is 480 cfm and the latter is 600 cfm and purrrfect for a 400M.
Old May 19, 2012 | 11:56 PM
Ok school me real quick, did ford make a factory 4v manifold for the 400?
And would any aftermarket manifold bolt up the 4100 then?
Old May 20, 2012 | 12:22 AM
HIO Silver's Avatar
HIO Silver
Dunno.... but 77-79s came with the 351M or 400 and that's subject to emissions testing which I avoid like a plague. I'm an FE and Windsor guy..... 75 and earlier.
If it's an aftermarket with a square bore, then my money is that it can accommodate a 4100 since the aftermarket typically caters to Holley square bore carbs.
IIRC, there are 351M/400 manifolds with and without EGR but both are square bores and 4100-able.
Old May 20, 2012 | 01:16 AM
fordman75's Avatar
fordman75
No Factory 400 4V intakes.
Yes the 4100 will fit aftermarket 400 intakes.
Old May 20, 2012 | 03:32 PM
What would be a good manifold to run with the 4100?
I would like to keep the heat stove, and if i can ditch the egr valve that wouldn't hurt my feelings.
Old May 20, 2012 | 03:51 PM
fordman75's Avatar
fordman75
A 4V intake!
It's been a few years since I shopped for 400 intakes. But I believe there are only 3 available.
An Edelbrock Performer, Edelbrock Performer EGR or a Weiand Action Plus. They are all pretty close to the same. I liked the more solid carb mounting base of the Weiand and the Performer EGR intakes over the Performer intake. But otherwise they are pretty close to the same.
If you want to keep the heat stove then you need to go with the Edelbrock Performer EGR intake.
Old May 20, 2012 | 08:59 PM
LOL.
Well I'll have plenty of time to find a good combo to run, this is going to be a future upgrade.
garypettengill
13
Sep 24, 2021 03:58 AM
mdr617
Mar 19, 2011 09:15 PM
truckman79
37
Jan 15, 2004 04:12 AM
79_250RangerLariat
Jun 12, 2003 03:04 AM
dbarracuda
Nov 18, 2002 05:03 PM
