6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Guess the Problem
Old May 22, 2012 | 07:45 PM
cheezit's Avatar
cheezit
egts are covered 3/50 only.
Old May 22, 2012 | 08:44 PM
RM2738's Avatar
RM2738
2008 MY's are 5/100,000 emissions on Diesels.
<a href="http://s68.photobucket.com/albums/i34/westwoodlands/?action=view&current=ecdc02fd.jpg" target="_blank"><img src="http://i68.photobucket.com/albums/i34/westwoodlands/ecdc02fd.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
Old May 22, 2012 | 08:53 PM
RM2738's Avatar
RM2738
Here is verbiage stating that sensors are covered.
List of Parts Covered for 5 Years or 100,000 Miles (whichever occurs first) by Emissions Warranties for Diesel Engines
• Air Flow Sensor
• Air Induction System
• Catalytic Converter (including Diesel Particulate Filter and Diesel Oxidation Catalyst)
• Cold Start Enrichment System
• Electronic Engine Control Sen-
sors and Switches
• Electronic Engine Control Unit (ECU)
• Emissions Label
• Exhaust Gas Recirculation
(EGR) System
• Exhaust Manifold
• Fuel Injection System
• Fuel Injector Supply Manifold
• Intake Manifold
• Intercooler Assembly - Engine Charger
• Malfunction Indicator Lamp (MIL)/On-Board Diagnostic (OBD) System
• PCV System and Oil Filler Cap • Supercharger Assembly
• Throttle Body Assembly (MFI) • Turbocharger Assembly
Important Information About List of Parts
Also covered by the two emissions warranties are all emissions-related bulbs, hoses, clamps, brackets, tubes, gaskets, seals, belts, connectors, non-diesel fuel lines, sensors, and wiring harnesses that are used with components on the list of parts, above.
Old May 22, 2012 | 09:10 PM
m-chan68's Avatar
m-chan68
Originally Posted by mich800
After doing research here this sensor is no longer considered part of the engine. Although, I emphatically disagree as without is it is a no go.
If you don't mind posting your VIN and mileage, as well as the specific EGT that failed, I can tell you right now if it's covered or not.
Remember, there are FIVE EGTs in total. And they are EGRT_A and EGRT_B, as well as EGT_11, EGT_12 and EGT_13. If you are unsure of the acronyms, I'll be happy to clarify them for you.
Old May 22, 2012 | 09:20 PM
mich800's Avatar
mich800
They ordered the part today and I do not know the part number or which EGT. The rep that called me she tried a couple different ways to get it covered under warranty but I don't know what that means.
I will try and call customer service tomorrow and see if I can get some goodwill out of the deal and maybe split the cost.
Old May 23, 2012 | 01:20 PM
mich800's Avatar
mich800
The vin is 1FTSW21R98EB74373; 75,000 miles
I still do not have the part number but I just got a call. They broke the DPF trying to replace it. So the sensor must be close. Now I also get a new DPF but that is under warranty.
Old May 23, 2012 | 02:17 PM
RM2738's Avatar
RM2738
That goes to show dealerships are just as responsible for Ford being sticklers on warranty claims. Tech breaks DPF and instead of dealership paying, they'll file a warranty claim and Ford will pay for it. Oh well. Nothing against you Mich.
Old May 23, 2012 | 02:19 PM
m-chan68's Avatar
m-chan68
Here's where warranty coverage falls under the "gray area". Just by the further information you've included, where they broke the DPF is a dead giveaway that EGT_13 is your culprit. After running your VIN and mileage, I was able to determine your EGT is NOT covered, if entered in as basic part number 5J213, but IS covered if entered in as basic part number 12B591 (under diesel engine part warranty). Your DPF however, IS covered under emission defect. Use this information provided, at your discretion.
Old May 23, 2012 | 02:20 PM
RM2738's Avatar
RM2738
I don't know how they could have broken the DPF unless the sensor was IN the DPF. All the more reason it should be covered per the warranty documents.
Old May 23, 2012 | 03:09 PM
RM2738's Avatar
RM2738
Ford Customer Service is your best option. My understanding is dealerships have retail costs and warranty costs. If my understanding is correct, the "stealership" will profit more on retail prices as warranty prices are per-determined by Ford as to how much they will pay out per anticipated man hour for a set labor rate and pre-negotiated quantity of man hours. I also believe that parts are charged at dealer cost for warranty work as opposed to retail cost obviously has dealer markup for overhead & profit. But, that's just my understanding and I have been wrong once or twice.
Old May 23, 2012 | 03:58 PM
mich800's Avatar
mich800
It was a no go on getting the part number changed. I called C.S. and now have a case number. I have a pretty good relationship with the dealer so hopefully they will discount the service. I really like the truck but the cost of ownership is definitly higher then all my other vehicles I have owned.
Old May 23, 2012 | 06:44 PM
cheezit's Avatar
cheezit
12b591 is nolonger a valid number here all thats available is 5j213's
so far as why the dealer is able to replace the dpf under warranty is simple the bung has also failed. Not your faults or the techs. Its a knowen that does happen. there is a tsb about retaping them if possible but I have had a few were that was not an option.
Old Nov 4, 2013 | 04:56 PM
  #28
Leon_D's Avatar
Leon_D
Those sensors break off in the DPF frequently. Fords answer when that happens is DPF replacement, but the aftermarket came up with a much cheaper repair:
http://www.ebay.com/itm/OE-style-exhaust-gas-temp-EGT-sensor-bung-for-Ford-Powerstroke-Diesel-6-4-6-7L-/141039388416?pt=Motors_Car_Truck_Parts_Accessories&hash=item20d69a4700&vxp=mtr
Even an article about it here: http://www.forddoctorsdts.com/articl...gt-sensor-boss
c502cid
Jan 18, 2026 09:54 AM
Amish Ford
1997 - 2003 F150
Jan 10, 2016 08:37 PM
rickfar
Escape & Escape Hybrid
Aug 20, 2014 05:42 AM
TXAggies1
2004 - 2008 F150
Feb 14, 2013 08:59 PM
TRITON-ic
2004 - 2008 F150
Nov 30, 2004 02:05 AM
