1978 - 1996 Big Bronco
ignition switch
Old May 19, 2012 | 07:53 PM
frenchy107's Avatar
frenchy107
ignition switch
I've got a 96 bronco. Turned the key and nothing happened, figured it was the lock cylinder, put a new one in, no change. Noticed that when i turn the key all the way back that it doesnt turn the electronics off. Thinking that the piece that slides in the column is broken. Any ideas on what this piece is called and if its easy to get a hold of
Old May 20, 2012 | 01:18 AM
greystreak92's Avatar
greystreak92
Hmmm, this was a bigger issue on the older (generation 4) Bronco and F-series. I've not heard too many instances of that particular part failing in the newer trucks. However, that means little if yours has failed. The part is often referred to as an ignition actuator link or arm. Again, since I've never replaced on in a newer truck, I'm not familiar with the way its mounted. I can have a look at it in the morning as I have a steering column out of a 93 sitting on the workbench right now.
squirrel64
17
Dec 9, 2013 07:59 PM
notsohandyinny
Mar 19, 2007 09:08 PM
atmbrown
Dec 5, 2006 10:26 PM
seanm88
23
Mar 13, 2005 06:18 PM
my89bronco
Jan 31, 2004 10:14 PM
