2wd power steering boxes
Old May 19, 2012 | 02:11 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
Does anyone know if they share the same pattern with the mounting bolt with the manual boxes? As in is it a direct swap? also does anyone know it a f150 4wd pitman are will fit on a 2wd box?
Old May 19, 2012 | 04:20 PM
fordtrucknut's Avatar
fordtrucknut
Same bolt pattern on a 2wd with manual or power steering box....steering column shaft is longer on a manual box tho....Yes an F-150 pitman will fit it...but if you are putting it on a 2wd it doesn't have the right angle at the end for the tie rods.
Old May 19, 2012 | 05:03 PM
crazyredneckanyhow
What ive got is a 75 F-350 2wd cab and chassis that im converting to 4wd. Im using a 89 D60. Had to outboad the springs so now i need an inside mount box.
Old May 20, 2012 | 03:42 AM
fordtrucknut
Look at this thread I did of my Highboy steering conversion....might give you some ideas with the 2wd box.
https://www.ford-trucks.com/forums/1...-late-90s.html
Old May 20, 2012 | 07:58 AM
crazyredneckanyhow
Yeah i looked at that. I did the same deal on a highboy a few years back. I just had everything welded in. It worked out really nice. The only difference now is that the 80s style 60 fronts have the inverted y steering like the 70s f150s used. So i need the rear facing pitman arm to have it all work out.
98Stang
21
Dec 4, 2020 05:01 PM
zakt
Apr 7, 2013 10:58 PM
76 crew
1966 - 1977 Early Broncos
Oct 24, 2007 05:27 AM
bocephus_3349
Sep 5, 2005 09:44 AM
skp428
Aug 16, 2004 08:29 PM
