1966 - 1977 Early Broncos
power steering box?
Old Jan 17, 2004 | 11:29 AM
skp428's Avatar
skp428
power steering box?
has anyone found a power steering box that will fit a bronco out of a diffrtent truck?
Old Jan 17, 2004 | 12:56 PM
Mike W's Avatar
Mike W
An 80's Toyota will fit by drilling one new hole in the frame.
Old Jan 17, 2004 | 06:24 PM
RCrawler's Avatar
RCrawler
86- 95 Toyota 4wd IFS
81- 90's Nissan 4wd
73-79 F series 2wd
77-79 F150 4wd, modified internals, mounts similar to the 2wd box, but with better drag link angles
mid 60's Lincoln Continental
Scout II 72-80
Jason
Old Jan 17, 2004 | 09:29 PM
skp428's Avatar
skp428
thanks for the help
Old Apr 1, 2004 | 07:41 PM
Cheshire Cat's Avatar
Cheshire Cat
Jason,
Do all the steering boxes you listed need to modify to mount in?
Do any of them mount the same as the stock manual box?
Wich box seems to work best IYO?
Old Apr 9, 2004 | 10:39 PM
RCrawler's Avatar
RCrawler
Most of them require some modifications to bolt up. From drilling and sleeving an extra hole, to adding a bracket on the bottom of the frame.
Some of them need some linkage modifications, both from the steering column and the steering linkage itself.
And custom hoses for the hydraulics. Some use a special parts store application, while others require a custom hose to be made.
I've driven both the Ford boxes, the Scout II, Lincoln, and the Toyota box.
I wouldn't recommend the 2wd box to anyone. The Lincoln had a very quick ratio could be difficult to control at times. The Toyota box gave me the best road feel, but it doesn't have the assist that some of the others do. I didn't have much seat time with the modified 4x4 box, but it seemed to have the best feel of all of them.
Jason
Old Aug 16, 2004 | 08:29 PM
2classics's Avatar
2classics
an F100 box also works if you can find one.
ldouble619
Ford Truck Parts for Sale
Oct 9, 2015 03:13 PM
brenthottle
Jul 11, 2014 06:02 PM
93truck
15
Sep 5, 2013 07:37 PM
atcrider1
Nov 25, 2011 12:20 PM
78_f150
Nov 17, 2011 11:14 AM
