Unfinished 64 4x4 project value needed
1962 Frame (registered 1964) ’64 cab w/flatbed 3.89 gears. Starting up front; closed knuckle diff.(stock) except I upgraded it to factory disks. GMC power steer box (saddle mounted). A 460 4brl sitting on a professionally welded cross member from a ’76 Lincoln with a C6 to divorced transfer (stock) case. Large, many leaf, rear spring pack (could be F350?) supporting a narrowed axle housing with a 31 spline 3<sup>rd</sup> member and large bearing axles. All new brake components including shoes and pads. New spring bushings and pins front and rear.
So the engine is freshly rebuilt with an rv cam along with the C-6. Most all the electrics are Lincoln including the complete wiring harness. Everything is Ford; walk in to any parts house and ask for stock items…
Ac (76 F100 factory & controls) , cruise control, 6 way power seats, power disk brakes, upgraded C-6, power steering w/tilt & locking column, tinted front window, delay 2spd wipers, gauges and idiot lights, receipts and complete list of changes (year & model), extra diff and misc. including grill and doors. Minimal rust and no crash damage just minor dents and abrasions. After all it is a nearly 50 yr old truck…. But…. She’s been sitting for 10 or 15 yrs since I did all this work.
So based on this…. What should I be asking for this nearly completed project? The major work is done just needs body work, bed, rims, & love.
I got it to this point and then bought a ’78 F250 4x4 and she has just sat waiting ever since. Unless needed; prime the carb (to save the starter), turn the key, good to go. She’s a good truck and no slouch either. Can carry most any load and will set you back in those Lincoln seats if you need to pass someone.
Eventually I hope to do is find someone who can appreciate the base I have provided and have the skills and foresight to complete her and restore her the rest of the way to the beauty/beast she desires to be. It wouldn’t hurt for the person to be shorter than 6’ tall as the Lincoln seats while comply do take up some room….
I know I shouldn’t take less than 1500 but I am so far removed from what I should ask that any help would be greatly appreciated! It’s been too long to recoup the cash I invested and since I did all the labor myself; well you know how that goes, how to charge for my many hours…… I did this for me not to sell!
P.S. If anyone wants to know how I did the front disk brake upgrade I would be glad to share that info. Not too hard or expensive and uses factory everything except special adapters which have to be machined. I hate fixed caliper “c*ap” that most change over’s use….. Mine is stock; brackets, dust shields, calipers, disks…..
Here's the before she got ignored.... Click to enlarge:
And now years later & less than 500mi more.... Please don't hate:
Yep,, you never get your money out of them
buy low,,, sell low
And has been stated many times,,, it is worth what someone is willing to pay for it,,, and from what I have seen lately,,, 460 with $4.50 gal gas just ain't a popular choice,,, stick it on CL for $1500 see what ya get,,, with all the rust underneath there,,, hard to say,,
Joe
No.... Just not a daily driver. Shes a turn key right now! I just stopped working on the project. Only used a few times a year and she purrs. The only thing that doesn't work is the AC doesn't blow cold.... But still has pressure in the lines and a lifetime warranty pump.
I'd put her up against any truck as she sits! Hauling weight or acceleration! No leaks; oil, water or rain.....
Thanks for the input though!
No mice! Surprisingly true.... I guess they have others, out in the field, they like better. No twigs, sticks or tracks....
Guess I'll stick to my original 1500 and find her a good home as my reward! Thanks for the replies! Glenn
I built it to be strong, it is a half ton, and last. She'll be around longer than these "new trucks"
I already have the problem with my truck. There are far more shops that will not touch it than those who will.
Just wondering. How many of this vintage 4wd truck do you think they made? Sounds like you think they made several thousand of them. If you think that you better guess again.
Lots of nice upgrades that people who currently own a pre I-beam F100 would like.
Most people looking for a 60s F100 arent knowledgeable enough to know what kind of work is involved in getting a truck to the point where yours is at.
Thanks for kind words! Continuing replies; good and bad are welcome
