Off road angles
Old May 18, 2012 | 10:04 PM
Mikey D1016's Avatar
Mikey D1016
Off road angles
Hi, I have a 2011 XLT screw with 5.5' bed 4x4. What is the most side angle you guys would consider safe? I have a spot in my lawn that when I drove on it it was at 14 degrees according to the offroad screen and that felt pretty steep. This is my first 4x4 and am not too sure of some things. Any help would be appreciated. Thanks Mike
__________________
Old May 18, 2012 | 11:03 PM
meborder's Avatar
meborder
we do a good deal of off road driving at work, mostly in the inslopes of roads and ditches.
your 14 degrees equates to a 4:1 slope, which by highway standards is considered "recoverable" meaning, if you were to leave the road, you could slow down and re-enter the road without fear of roll-over.
untill you get used to it 4:1 feels steep. i don't even begin to concern myself until i get on a 3:1, (19 degrees), at which point i slow down and look for pot holes that could make a corner dip and throw the truck off balance. realistically, this probably wouldnt happen until you exceeded 2.5:1 (23.5 degrees).
generally speaking, if the truck is empty, and especially if you are on loose soil or grass, the rear end will slide downhill before the truck even comes close to tipping. All bets are off if you have the bed loaded, especially with something that could move around like a water tank.
maybe there are some hardcore off road'ers around here that can add to or dispute any of the above, but that's what i've learned. and all of that in a 4x2 cauz "we don't need 4x4's"
Old May 19, 2012 | 07:13 AM
Mikey D1016
Thanks,that makes sense. I was just wondering how far it could go. It kind of freaked me out a little, but that may have been because the drivers side was downhill.
Old May 19, 2012 | 08:46 PM
juneau76's Avatar
juneau76
Some pretty good info here. Unfortunately, the rep police have me in time out. As an off-roader (not my F-150), I'm not fond of the big off camber situations.
Old May 19, 2012 | 10:35 PM
meborder's Avatar
meborder
see edit below:
sorry, i had my tangent and sine functions corn-fuzed ... didn't want to present bad info since your truck reads in degrees, not slope (cauz engineers are the only ones who use slope ... and that's only because we're wierd to the outside world)
regardless, anything past 19 degrees (3:1) and i start to be more cautious about what i'm doing. at 22 degrees, i'm at a crawl hangin' on to the door, and wishing i didn't have to be.
edit: 2.5:1 slope is actually 22 degrees.
Old May 20, 2012 | 09:39 AM
h2ouup2's Avatar
h2ouup2
About 22.8 degrees is the max.
2012 Ford F-150 | View Exterior Specifications | Ford.com
Old May 20, 2012 | 12:43 PM
meborder's Avatar
meborder
the link above refers to approach and departure angles, and those numbers are correct for a "head on" approach.
i think the OP is referring to cross-slope, which incidentally is about the same angle.
at least according to my calibrated "puckerometer"
srkr
Dec 11, 2016 05:01 PM
69satelite
2009 - 2014 F150
13
Oct 1, 2013 07:18 PM
dieselkid
23
Aug 26, 2009 09:49 AM
lostin90s
Pennsylvania Chapter
Aug 27, 2007 04:25 PM
