1978 - 1996 Big Bronco
Consequences of spring cleaning?
Old May 18, 2012 | 09:30 PM
Captbs32's Avatar
Captbs32
I decided to do some cleaning in the engine bay of the 1981 Bronco 4.9L. I do not plan of having a/c until I can get a lot of other items for the truck. Soooo that being said I removed the ac condenser along with ever hose for the ac and other stuff. Any negative effects?
Old May 19, 2012 | 01:15 AM
greystreak92's Avatar
greystreak92
The condenser or the compressor? Neither will have any ill effects unless you want cold air out of the vents when there is only hot air to be had.
Old May 19, 2012 | 06:50 AM
AzPete's Avatar
AzPete
I believe the defroster uses cool air to help it clear a fogged over windshield also. If yours was not functioning anyway, removing all the under hood items will only make it more difficult to restore once you get tired of the hot air inside....
Old May 19, 2012 | 10:49 AM
Captbs32's Avatar
Captbs32
Gray, the compressor has gone also but I took out the condenser yesterday in a way that i could get everything back together one day if the condenser doesn't have a hole in it somewhere. It looked in alright shape, a couple places had a few fins damaged so look alright.
AZ, ya I have not had the a/c hooked since I got into the "restoring" it. The only reason I took the condenser out is because the driver side line was kind of fused to the condensor itself. I remember it being pretty straight forward to replace the condensor to instead of risking damaging anything with frustation I just removed the whole component.
Thanks both of you guys for the knowledge!
Old May 25, 2012 | 08:32 PM
Bubba Jones's Avatar
Bubba Jones
Be careful with the condenser though if your AC compressor is bad. Often times its too hard to flush out all the debris out of the condensers so if you get a new AC compressor and reuses the old condenser, you could manage to get debris in the new compressor and it will eventually fail..
edit: eventually as in a few months or less depending on how much debris is stuck in the condenser.
Old May 26, 2012 | 01:50 PM
Captbs32's Avatar
Captbs32
Ya that thought crossed my mind as far as the trash in the lines. I never followed up with it.
I was think when I get the money or just want to make AC a priority I will do a whole new system.
Thank you for the response.
mr.fordneck
Jul 8, 2012 11:59 PM
gillman
Nov 24, 2006 07:36 PM
kjg26
13
Nov 25, 2005 01:50 PM
HENDEL JR
Jul 5, 2005 03:51 AM
F0rdF0rever
Apr 29, 2004 03:20 PM
