3G install
Old May 20, 2012 | 06:02 AM
jowilker's Avatar
jowilker
Originally Posted by Shadowrider123
I didnt really see any text talk in my post. AZ=Autozone. Im not a youngn either, I dont text.
Please forgive me friend, here in North Carolina 3G is on my cell phone and AZ is still Arizona.
While my first response was a little tongue in cheek, I had no idea what you were referring to. See how further dialogue has you trying to blow your yellow horn with 3G.
John
Old May 20, 2012 | 06:33 AM
OldStyle's Avatar
OldStyle
Rusty Roller
That 3g Alt should have one , main hot (red), going to the hot side of the solenoid. Another , Yellow, wire also going to the Hot side of the solenoid. The other is a smaller wire connected to a switched hot. That is the one that tells the alt that the ign is on and time to produce power as soon as the engine is running.
That wire is one of the wires that used to go to the former v-regulator and comes from the ign switch; hot only when the switch is in the "run position".
Old May 20, 2012 | 10:28 AM
Shadowrider123's Avatar
Shadowrider123
I have the 3G wiring figured out.
I have the 3G harness of the donor, ther are only 3 wires to hook up.
1. Ground from 3G to block
2. Hot from 3G to solenoid.
3. Red/grn from 3G to red/grn off the old regulator.
I now think someone rewired the horn relay and the yellow is power from the solenoid to the horn relay.
Thats how Im going to hook everything up.
Old May 21, 2012 | 02:37 PM
oldfordcoupe's Avatar
oldfordcoupe
you can also find these alt. on v6 tarsus just make sure that they have a good grd. i put one on my slick an my 77 bronco also its well worth it
Old May 21, 2012 | 03:28 PM
rustywheel68's Avatar
rustywheel68
you may be on to something there...whoever gets my truck next is going to have a good time figuring out all the changes i made...
keep us posted.
Old May 23, 2012 | 07:53 PM
limpysmalls's Avatar
limpysmalls
I really like what you did with the alternator bracket. You say Mr. Gasket, do you have a part number? I like that option better then finding the low mount brackets that are getting harder to get.
Old May 23, 2012 | 10:55 PM
Shadowrider123
Mr Gasket p/n 9851. Its the only one Advance carrries.
Im on the lookout for the low mount.
Im going to try to dechrome the bracket. Chrome does not like bleach.
luke000
Mar 14, 2023 02:49 PM
1ford1
Sep 20, 2006 11:34 PM
jaswolfie
Dec 28, 2005 11:20 AM
JIMY
Electrical Systems/Wiring
Aug 11, 2004 02:08 PM
go_go_gadgit
Jul 23, 1999 01:13 PM
