400 CID REBUILD TIME.
Old May 21, 2012 | 09:52 PM
crsmiffy's Avatar
crsmiffy
yes that is right. All the cleveland family heads will interchange, you just have to get the ports and combustion chambers to suit the application.
The 351m-400's benefit as their compression was pretty low and you bump it approx 1 point, so 8.5 will go to 9.5. As long as it wasnt rebuilt with high comp pistons (pretty unlikely) should be the go.
Old May 21, 2012 | 10:09 PM
chamblizi's Avatar
chamblizi
i got a new fuel pump today for my ranchero it says on the box it is recommended to clean out the tank when changing the fuel pump. Would that be necessary due to the pump is not located in the tank? eventually i will have to modify my gas tank anyway because i have to seal off my gas tank so fuel will not slosh on the ground. then have a old piece of brake line welded to the filler neck to vent it.
Old May 21, 2012 | 10:22 PM
crsmiffy's Avatar
crsmiffy
Definitely clean that tank out. Could be water/rust/fuel bug etc anything in there to ruin a fuel pump and clog jets in a carby, doesnt matter if the pump is in the tank or not. Would be well worth the pain IMHO.
While you are at it, if it doesnt have a fuel filter, buy one of those little plastic jobbies from repco/supercheap etc and put it in the fuel line just before the fuel pump.
As an aside why is fuel sloshing on the ground? Added bonus of removing tank would be the chance to get at it's inspection plate and weld/braze a fitting in for your extra vent whatever thats for.
Old May 21, 2012 | 10:46 PM
chamblizi's Avatar
chamblizi
fingers crossed mate. That would be good if that is the problem
yeah i hope so btw
here is a quick video its funny it is a prime example of the rap industry ....
Check out "Aries Spears - F@*k A Book " on youtube thru vevo
Old May 21, 2012 | 10:51 PM
chamblizi's Avatar
chamblizi
Its common problem with rancheros and el clampinos they throw gas out the filler neck.
Old May 21, 2012 | 11:13 PM
crsmiffy's Avatar
crsmiffy
Go to the wreckers and see if there is one of those flappy inlets like the late model commodores and falcons have. If it is like my galaxie you should be able to undo the top pipe from the tank and weld it on the bench without blowing the joint up.
Old May 21, 2012 | 11:53 PM
chamblizi's Avatar
chamblizi
my filler neck is still damaged i have the flap it needs to be welded.. bad thing it the filer neck and the tank is all one solid steel peice.
Old May 22, 2012 | 12:13 AM
crsmiffy's Avatar
crsmiffy
One piece-typical. Sounds like you have a few good reasons to rip it out
Old May 22, 2012 | 12:32 AM
chamblizi's Avatar
chamblizi
lol i have to be cash efficient right now... i am working on getting into community college.
I like the all one peice filler kneck so no one will take the time to be crafty to cut it off like they do a hose an sifon all the gas out... Metal takes some time to cut and here i have had gas stolen from me before.. I always keep lock gas caps and make sure i have a metal casing around my filler necks.
Louislindsey72
Feb 19, 2015 09:43 PM
crsweet78
Jun 3, 2012 05:59 PM
shorty2tall
May 15, 2012 09:54 PM
daddies77-400toy
May 5, 2012 06:26 PM
tcbofade
Mar 29, 2007 03:45 PM
