Depend on how thick your wallet is. First of all you want to raise the compression ratio in the 9 to 1 range.
Need new piston anyway check with www.tmeyerinc.com . He have the piston you need and much more. Change the cam for your application...daily driver, towing, race muding, street ,strip....A 4 brl intake, carb and headers to take advantage of those change with a straight-up timing chain. Don't be affraid to ask.
Need new piston anyway check with TMeyer, Inc. Precision Automotive Machining . He have the piston you need and much more. Change the cam for your application...daily driver, towing, race muding, street ,strip....A 4 brl intake, carb and headers to take advantage of those change with a straight-up timing chain. Don't be affraid to ask.
^^^^^X2 on what he said.....^^^^^ I think the most common is change out intake, carb get a bigger cam (RV type) and dual exhaust and you sir...will be amazed.
