CEL ?
Old May 18, 2012 | 03:01 PM
j250hd's Avatar
j250hd
CEL ?
Is the only way to get it to turn off through the obd II port? I had a bad map sensor and replaced it and it's still on.
Old May 18, 2012 | 03:02 PM
ToMang07's Avatar
ToMang07
Disconnect the batteries and let it sit over night. Should be enough to re-set it.
Old May 18, 2012 | 03:11 PM
Hussler's Avatar
Hussler
CEL will turn off after you replace the defective part. Code in memory will remain for a period of time though. What's the code ?
Old May 18, 2012 | 05:37 PM
j250hd's Avatar
j250hd
Not sure on code. Took it to the ford dealer and they told me I needed a new map sensor.
Old May 18, 2012 | 10:11 PM
oldbird1965's Avatar
oldbird1965
If you paid them to read codes then your entitled to know the number of the code. God I hate dealers!!!!!!!!!!!!!!!!!!!!!!!!!!
Old May 18, 2012 | 10:15 PM
j250hd's Avatar
j250hd
I don't pay. Luckily I have two cousins that are mangers there so the stealership is my best option next to doing it at home.
Old May 18, 2012 | 10:33 PM
oldbird1965
Oh, that's good!
Old May 18, 2012 | 10:58 PM
j250hd's Avatar
j250hd
It's actually really nice cause I don't get jerked around, I get parts at cost, and my labor rate is 60/hr if I ever have them do the work. Which is rare. Just mostly get diagnostics done and parts for cheap! if they weren't there I would never even set foot on their lot.
4bigred
6.7L Power Stroke Diesel
Feb 4, 2016 01:09 PM
mike L
Feb 28, 2010 07:51 PM
pmibach
1978 - 1996 Big Bronco
Mar 28, 2007 10:45 PM
