Sponsored by: Real Truck
Identify that part??
Old May 18, 2012 | 11:45 AM
vkite's Avatar
vkite
Heya! 97 F-350 4x4
THe lift came out easy but now i have this bracket attaching to what i think is called a sway bar behind the axel. Looks like this thing is supposed to have some give to it, but it's shoving the front end out of alignment to the passenger side. Can some one tell me what this arm and bracket are called so i can look up stock parts and see if I need to replace?
Old May 18, 2012 | 12:27 PM
cbzdel's Avatar
cbzdel
Looks like a trac-bar aka panhard rod to me..
Old May 18, 2012 | 01:00 PM
vkite's Avatar
vkite
awesome! thank you!!
Old May 18, 2012 | 01:04 PM
ToMang07's Avatar
ToMang07
Yup, looks like a drop bracket for the track-bar.
Old May 18, 2012 | 01:16 PM
Parts Jimmy's Avatar
Parts Jimmy
It is not stock. The stock one is all one piece. Not two pieces welded together. That looks weak.
Old May 18, 2012 | 01:19 PM
vkite's Avatar
vkite
You mean the bracket or the rod?
Old May 18, 2012 | 01:25 PM
cbzdel's Avatar
cbzdel
he is talking about the bracket..
Just thinking off the top of my head, if I recall correctly, not all leaf sprung front suspension vehicles have track bars.. That being said it sounds like you just got a lift kit, did it come with anything to adjust this trac bar? If not then YES it will pull the whole axle to the left.. To remedy this you would need a taller drop bracket for the track bar, or an adjustable trac bar..
Old May 18, 2012 | 01:34 PM
vkite's Avatar
vkite
Actually just took out the lift, trying to get it back to stock . What you said makes sense and would explain the opposite, it pulling right.
Old May 18, 2012 | 02:58 PM
cbzdel's Avatar
cbzdel
Gotcha, then yes you just need a factory size trac bar bracket, time to hit the junk yards
Old May 18, 2012 | 03:07 PM
vkite's Avatar
vkite
Can't order a new one? 97 350's are a little difficult to locate
Old May 18, 2012 | 03:12 PM
ToMang07's Avatar
ToMang07
Not too many companies making new parts for a 16 year old truck. You could try the Ford dealer to see if they have any left.... Best bet would be a junk yard or finding one somebody took off to add their lift.
Ruffasacob
Aug 6, 2019 07:30 AM
Kongerup
Jan 4, 2016 12:27 PM
ToMang07
Maine Chapter
Jul 2, 2014 02:27 AM
njneer1
Jul 18, 2011 08:53 PM
CBFryman
Aug 17, 2006 12:21 PM
