ball joints
Old May 18, 2012 | 09:50 AM
captain2207's Avatar
captain2207
ball joints
What is the easy way to check ball joints?and when do I stop pushing luck(if you will)with it?I ask because I took truck to tire, front end shop to get tire fixed.I asked if they could look at why rf tire looked a little tilted in at fender.I picked truck up he hands me a $1100 quote for ball joints.the only thing I see abnormal is at 72ish mph it has little vibration.any other speed its smooth. Thanks all
Old May 18, 2012 | 03:48 PM
pdqford's Avatar
pdqford
Jack the wheel about an inch off the ground. Have someone slide a crowbar under the tire and lift the tire up with the crowbar while you are under the truck feeling/looking for any movement at the upper and lower ball joint.
Just imagine the ball joint snapping off at 72 MPH.
Old May 18, 2012 | 04:04 PM
captain2207
Having it snap would suck cat ***!
bigcountry1009
Jun 19, 2014 03:28 PM
Sgt. Jackass
Feb 11, 2013 06:35 PM
SSSimon
Apr 27, 2012 07:23 AM
arno
Feb 6, 2008 09:57 AM
Broncobigtire
1978 - 1996 Big Bronco
Mar 19, 2004 08:54 PM
