6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Speed Control
Old May 17, 2012 | 08:27 PM
pyro2nite's Avatar
pyro2nite
Speed Control
I know there are several switches, brake, clutch, that turn off the speed control. Mine started working intermittently and now just quit. What switch or maybe not would be the most likely?
Old May 18, 2012 | 05:04 AM
senix's Avatar
senix
are you saying your cruise control no longer works? Or your speedo?
Or
are you saying you want to go faster then 95 mph?
Old May 18, 2012 | 08:26 AM
Tom's Avatar
Tom
Or
I think he's talking about his cruise.
It could be the switch, clock spring, or any wiring attached to either. Not sure about a common failure point, but I would suggest not simply throwing parts at this. Maybe someone knows the correct procedure to troubleshoot the switches.
Old May 18, 2012 | 09:36 AM
pyro2nite's Avatar
pyro2nite
Yes, the cruise control quit.
Old May 18, 2012 | 10:03 AM
senix's Avatar
senix
I'd be looking at the switch. But yes find the correct procedure first to troubleshoot.
Old May 18, 2012 | 10:07 AM
pyro2nite's Avatar
pyro2nite
There are several switchs..............which one?
Old May 18, 2012 | 02:26 PM
Rudiak's Avatar
Rudiak
I have the same problem. It is hard to find intermittant faults. If I had to shotgun a part I would go for the brake psi switch on the master cylinder. The forward one. It has fixed others I have seen and it's easy to change. Good luck and report back if you find a good fix.
Old May 18, 2012 | 02:32 PM
4X4 IN REFUGIO's Avatar
4X4 IN REFUGIO
It is likely the Brake Control Switch.
This switch is located under the brake master cylinder and is the one towards the front of engine. This normally closed switch allows power for the cruise to work. When the switch fails intermittently then so does the cruise control.
It's and easy fix and the part is around $35.
This recently had to be replaced on my truck and fixed the problem.
Old May 18, 2012 | 07:56 PM
Gearitis's Avatar
Gearitis
I had the brake control switch issue, I used some contact cleaner and sprayed it and cleaned it up. That was about 18 months ago. Worked like a charm since...
Old Jul 30, 2012 | 01:21 PM
pugster's Avatar
pugster
Red face Photos
Can anyone post pics ?
Getting up under the master cylinder sounds simple enough to talk about.
Old Jul 30, 2012 | 01:57 PM
pyro2nite's Avatar
pyro2nite
With mine it was the brake control switch. If you look at the bottom of the master cylinder, there are two switch's. The on that is facing the front of the truck. Or the one on the left if you are looking at it from the left finder.
explorer302
Nov 12, 2018 11:08 AM
ABCandJRC
1997 - 2003 F150
Nov 10, 2015 07:37 AM
gr8tdragon
Oct 13, 2008 04:55 PM
MISSFIRE1
Nov 12, 2006 10:19 PM
