need help with dampener problem in 460
Old May 4, 2003 | 05:25 PM
footdowninsanelaugh's Avatar
footdowninsanelaugh
Question need help with dampener problem in 460
i need help with my 460. i bought it about 4 days ago, and took it fishing. when i went to start it up yestreday i heard a clank. poped the hood, got under it, ect, and found that the dampener was loose. the ring(with the timing marks) right behind the crank pulley was completely loose, to the piont where it spins freely on top of the ring under it.
i cant find bolt holes in it, and its way too loose to have been a press fit. so how would i go about fixing it? just replace it?
what caused it? how is it supposed to attach in the first place? any ideas?
if it ran like that a while, i'm worried what damage was done internally, but i'm planing a rebuild anyway. i just wanted to play with the truck a while before i had to.
B
85 x-cab f-250 4x4 460
Old May 4, 2003 | 06:44 PM
DPW's Avatar
DPW
Lightbulb need help with dampener problem in 460
Sounds like the rubber between the two has came out. Replace the balancer with the correct one for your motor.
Old May 4, 2003 | 06:46 PM
georgedavila's Avatar
georgedavila
Sounds like you sheared the woodruff key. That's a piece of metal that fits in a groove in the crank snount that the dampner, with a grove that fits the key, slides on the crank to keep it from rotating. The crank bolt then hold the dampner from forward motion.
Pull the dampner and you'll see the keyway.
Old May 4, 2003 | 08:54 PM
footdowninsanelaugh
ok, thanks. is the dampner hard to pull? it looks like i'll have the clearance with out pulling the radiator, but if i have to get a puller in there the radiator will have to come out.
Old May 5, 2003 | 06:26 AM
DeenHylton's Avatar
DeenHylton
You'll need a puller to take it off. If it comes off by hand it was way too loose anyway. You should be able to rent a puller from a local auto parts store.
Deen
Old May 7, 2003 | 12:43 AM
footdowninsanelaugh
ok thanks for the help.
heres what i learned: the bolt in the center of the pulley is a 9/16 and a wailing bitch. but you can lock up the fly wheel to stop the engine from turning. i also used a 48 inch pipe wrench on the smaller ring of the dampner to hold the crank(since it was coming apart, i worked it all the way apart to get the wrench on it)
o'rileys stocks the dampner for 112.00 i found it new at a mom and pop store for 80.
orileys also sells a decent puller for 17 bucks. i'm hanging on to it.
i also decided to change out the water pump since its the original one, even though the truck only has 65k miles on it(not bad for an 85, but it belonged to a local rancher and the truck never left the ranch). new hoses, belts and plugs while i was there too.
body lift (2in) is next. the truck was exposed to alot of dust and farm chemicals and i've noticed alot of the soft parts are dry rotted.
runs great though, and got it for $1950 bucks, so i'm happy.
thanks yall.
Brian
Old May 15, 2003 | 08:34 PM
Dartagnan00001's Avatar
Dartagnan00001
Make sure you check the timing, you don't know how long the ring has been loose and spinning on the shaft....
Dart
Old May 15, 2003 | 10:01 PM
Colossus's Avatar
Colossus
LISTEN TO DART!!!
Old May 20, 2003 | 12:48 AM
footdowninsanelaugh
uhhh. i changed it out about a week ago and didnt check the timing. is this a bad thing? so what will i be fixing next weekend?
Old May 20, 2003 | 06:39 AM
georgedavila
Unless you pulled or moved the distributor, the dampner shouldn't have any effect on your timing.
Old May 22, 2003 | 12:03 PM
footdowninsanelaugh
dude george, you rock. i'm ok then.
Old May 26, 2003 | 10:18 PM
Dartagnan00001
Damper is constructed of two pieces of steel "secured" together by a pressure fitted piece of rubber. Rubber goes bad, no longer secured. Outer ring has TIMING MARKS impressed into it. If it's no longer "secured", then marks are no longer accurate. So it doesn't matter if distributor was removed, what matters is:
Were TIMING MARKS still accurate last time engine was timed?
Dart
07Wolfie
Sep 11, 2018 07:51 PM
Chevy Guy Gone FORD
Oct 30, 2013 08:47 PM
Blackfoot Big Block
Dec 3, 2012 11:05 PM
SEAL1
Dec 21, 2011 03:45 PM
98SurplusExpy
Feb 6, 2010 04:48 PM
