air compressor
Old May 17, 2012 | 05:34 AM
Liquid10Rider's Avatar
Liquid10Rider
air compressor
hey guys i have just purchased a firestone air helper spring kit with front and rear air bags, and a comp with .5 gal tank. Does anyone else run a compressor for either air bags or air horns and where did you mount the compressor so it doesnt get destroyed from water and debris from the road?
Thanks,
-AJ
Old May 17, 2012 | 09:27 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
AJ, I only have air horns and I mounted both the compressor and air tank in the bed of the truck all the way forward. I have heard mounting under the truck can be tough on the relay that operates the pump as well as debris hitting it if you do alot of offroading. If you do mount it under the truck make sure you pipe the air intake somewhere where it wont ingest dirt, water etc.
Check out this post: https://www.ford-trucks.com/forums/1...ompressor.html
Old May 17, 2012 | 09:48 AM
Christof13T's Avatar
Christof13T
inside a sealed ammo can.
my compressor is mounted under bed passengers side about 2 1/2 feet back from the cab... kinda estimating since im not looking at it (she's in seguin till next week) and the ammo can is bolted upside down... compressor mounted inside it. have it plumbed to breathe from inside the cab... and have a 3 gal tank mounted just behind the ammo can. have a quick connect on both sides of rear bumper...
cheap and absolutely effective.
xtof
Old May 17, 2012 | 10:54 AM
Shake-N-Bake's Avatar
Shake-N-Bake
My pickup has an Airlift Load Controller compressor mounted under the truck on the inner rocker. It comes in a plastic case that seems to protect it fairly well. It's been there for years without any issues.
My F450 has a Gast Manufacturing Roc-R air compressor mounted in the tool box.
As far as noise goes...the Airlift pump is pretty loud, it will stop conversation while operating. The Roc-R compressor is barely audible. I have to open the tool box door to hear it running. They both are good pumps and are designed for different uses. I've been pretty happy with both models.
Old May 17, 2012 | 11:21 AM
Tugly's Avatar
Tugly
You can always get serious about it. [LINK]
Old May 17, 2012 | 11:48 AM
snakedoc's Avatar
snakedoc
im building one like that to go where the second alternator should be.
Old May 17, 2012 | 12:11 PM
empiretc's Avatar
empiretc
Behind the back seat on the passenger side. The is a hole there that was perfect to route the air hose through.
It's been there for 7 years now, and the only abuse it has gotten is from using the air horns too much.
Old May 17, 2012 | 12:56 PM
kccatpower's Avatar
kccatpower
am i missing something here? all you get is the compressor which is an a/c compressor. bracket, filter, brass fittings not included. you would still need the belt to run it, wiring, relay and switches. looked at the accessory section and did not find a kit to install this. off road guys have been using old a/c comp as air comp for along time and they work well.
Old May 17, 2012 | 01:01 PM
snakedoc's Avatar
snakedoc
all he sells is the comp no brackets or belts tank.
that is way im building my on kit.
Old May 17, 2012 | 08:33 PM
robinsonpowerstroke's Avatar
robinsonpowerstroke
Well here is a couple of pics my Viair air compressor:
Here is my supply tank, it is a 11 lb propane cylinder:
Old May 17, 2012 | 09:17 PM
WA.Ranger's Avatar
WA.Ranger
That's one project I need to finish.....and Luny1's too!
Old May 18, 2012 | 06:21 AM
Firefighter 1406's Avatar
Firefighter 1406
Mine is mounted driver side under extended cab seat. Have air intake also in the cab. The salt up north would kill a compressor. Dry quickly.
Old May 22, 2012 | 05:04 AM
Liquid10Rider
xtof
Do you have any pictures of your comp mount with the ammo can? did you put any holes in the ammo can to let out any heat from when the comp is going??
-AJ
Old May 22, 2012 | 08:10 AM
Christof13T
ill take some pictures and post them today.
no breather holes... would defeat the purpose of having a sealed box... but now that you mention it... i may come up with a cooling system for it fed by the air tank.
so far it has not been an issue.
xtof
Old May 22, 2012 | 10:16 AM
kccatpower's Avatar
kccatpower
snacdoc, if you figuere out how to make the bracket let me know, i went to extremeoutbacks website and they show the mounting kit $799, you still have to buy the compressor. if you are serious about building this set up i will check and see if i can come up with a used a/c comp of a big rig.
