Explorer a/c help
Old May 16, 2012 | 09:28 PM
Jacobs Daddy's Avatar
Jacobs Daddy
Explorer a/c help
Hey all, I have a 2000 explorer and the a/c stopped working. I recharged the a/c because freon was low per the gauges and then the compressor would kick on, then the pressure would drop in a matter of seconds and it kicked off again. Then the pressure goes back up, compressor kicks on again and this just keeps doing this over and over but never gets cold. What's wrong? My a/c worked last year. Anyone have any idea?
Old May 17, 2012 | 06:08 AM
critterf1's Avatar
critterf1
What do the gauges read?
Old May 17, 2012 | 06:30 AM
projectSHO89's Avatar
projectSHO89
There's a set of FAQs in the HVAC section. While written with the F-series in mind, it also applies to your situation.
Old May 17, 2012 | 08:08 AM
Jacobs Daddy
45 psi then compressor kicks on and drops to zero then kicks off
Old May 17, 2012 | 01:16 PM
shorod's Avatar
shorod
45 psi on both the high and low pressure side, or are you only monitoring the low pressure side? Does the gauge needle shake at all or just drift to zero?
-Rod
Old May 17, 2012 | 01:34 PM
Jacobs Daddy
45 just in low. Needle just drops steady(and fast).
Old May 17, 2012 | 02:46 PM
KhanTyranitar's Avatar
KhanTyranitar
You need to watch both high and low side. To me it sounds like your system is either plugged, or you are undercharged, but its impossible to tell unless you watch both high and low. This is part of why the DIY cans with the built in gauge and worse than useless.
JRF
Sep 22, 2012 07:46 PM
hvacmaniac92
1983 - 2012 Ranger & B-Series
Jul 23, 2011 04:46 PM
Weasel's_Truck
Sep 8, 2004 02:31 AM
jscozz
22
May 17, 2004 07:52 AM
daleg
Jul 31, 2002 06:13 AM
