a/c compressor cycling
Old Nov 12, 2000 | 06:41 PM
daleg's Avatar
daleg
I am a new Explorer owner (97 Sport 4x4 SOHC) and new to this site, which is great by the way!
When I set the climate panel to any setting which requires the a/c compressor to run (defrost, a/c, etc.), it short cycles (1 second on- 1 second off) and the idles jumps from about 400rpm to 1000rpm while doing this. My first thought was low on freon, so I disconnected the low pressure switch and shorted out the connector pins, but compressor still short cycles. Next I swapped the WOT a/c relay in the fuse box with another one like it, still no help. What else sends a signal to the clutch for engaging/disengaging? When the truck is at idle with any settings on the panel where the compressor isn't supposed to run then it idles smooth. I've only had the truck for 6 weeks and I just got it out of the shop (2 weeks ago) for the dreaded camshaft tensioners and the intake gaskets were replaced as part of that repair. Has anybody figured out what is causing this?
I really like the Explorer and I live in Louisville where they are made. I was hoping to help the local economy by buying one (the assembly plant, not the service department), but when do the repairs stop on this thing??
thanx
Dale
Old Nov 12, 2000 | 11:00 PM
PAUL_2's Avatar
PAUL_2
You need to have the system checked to make sure it has the proper amount of R134A . You cant diagnose any problems other than the obvious if the system is low on R134A .
Old Nov 13, 2000 | 07:03 AM
daleg's Avatar
daleg
>of R134A . You cant
>is low on R134A .
Thanks for the reply Paul!
If I shorted the connector for the low pressure switch for the freon level, wouldn't that bypass any low freon condition and cause the compressor to stay engaged? I have tried that and the compressor still short cycles. The WOT relay also opens and closes with each cycle, so I feel that something electrical is telling the clutch to turn off and on. Is there some other switch or solenoid that sends the clutch a signal?
Thanks again,
Dale
Old Nov 13, 2000 | 09:47 AM
PAUL_2's Avatar
PAUL_2
Im not really familiar with the A/C system on your Explorer , but I think the system also works with a temp sensor that reads the outside ambient temp ? A great site for A/c related things is http://www.aircondition.com . There are a couple of A/c techs there that really know their stuff .
Old Nov 20, 2000 | 06:56 AM
qwpo's Avatar
qwpo
Paul is correct; there is an ambient air temp sensor that comes into play, along with the WOT switch and the pressure sensor. I had the same problem and mine was due to low freon.
Old Jul 25, 2002 | 11:35 AM
1965ford's Avatar
1965ford
did you find out the cause of the AC cycling? Mine is doing the same and the dealer told me that the R134 is up where it should be.
neal.jackson@amec.com
Old Jul 26, 2002 | 10:12 AM
winfordr's Avatar
winfordr
I don't know the location, but there is also a hi pressure switch. By law, the r134 systems are supposed to shut off with high pressure just like low pressure (to prevent venting to atmosphere).
I would definitely get a set of gauges and check the pressures before spending any time or money otherwise. Or have an a/c technician do it for you.
Winford
Old Jul 29, 2002 | 07:16 AM
daleg's Avatar
daleg
Well I have tried numerous things and now only have the problem very rarely.
I believe it was related to a low freon condition, I have recharged the system and really dont see the problem much at all anymore.
Some other things I have tried that seemed to also help was clean the IAC, Throttle Body and MAS sensor. Everytime I would clean these the problem would go away also, so I'm not real confident on what actually caused it. I would suggest cheking your freon level first, preferably with guages so that you can be accurate, and you may want to clean the above listed components, that also seemed to help.
Dale
Old Jul 29, 2002 | 10:07 AM
Babcore's Avatar
Babcore
You've said the WOT relay cycles. I believe the electrical path for the AC clutch feed is that the control from the dash feeds the pressure switch, then it goes through the WOT relay to the AC clutch.
Your computer is cycling the AC clutch ( you can verify this by removing the WOT relay and shorting the NO contacts). Unless the Computer is getting a pressure signal from the AC system and shutting you down for High pressure, then High pressure cutout isn't your problem.
I would be trying to find out if the computer is getting a signal which makes it think you have a WOT condition.
Old Jul 31, 2002 | 02:27 AM
fauxexplorer's Avatar
fauxexplorer
also engine temp will cause ac to drop out.but its normal for ac to cycle on and off every 10-15 seconds or so on all 98+ in any selector position except the vent position and off
Old Jul 31, 2002 | 06:13 AM
adbradley's Avatar
adbradley
