Question about bench seat
Old May 16, 2012 | 05:10 PM
jerd_hambone's Avatar
jerd_hambone
I have an 84 F150 extended cab, automatic.
I'm considering putting a bench seat in the front and getting rid of the factory buckets.
My questions are:
Do the factory bench seats tilt forward? Or are they fixed?
And are the outer floor mounts the same? Or would I need to find a different mounting setup?
Old May 16, 2012 | 05:21 PM
ctubutis's Avatar
ctubutis
Yes, they tilt. I would imagine the floor mats are the same.
Old May 16, 2012 | 05:26 PM
Dave804's Avatar
Dave804
Odd to be going that direction with it. Work truck? Should be very easy to unload those buckets.
Seems like guys that go the opposite direct it's plug and play on the outer mountings. Should be good
Old May 16, 2012 | 06:28 PM
jerd_hambone
I just enjoy the extra space haha. I've never really been a fan of buckets. I enjoy being able to lay down and stretch my legs when I need a break.
Any idea if they tilt?
Old May 16, 2012 | 06:55 PM
WilleyJoe.62's Avatar
WilleyJoe.62
My sister was up for the weekend and I took her for a spin in Festus. She kept marveling at the bench seat, as she hadn't seen one in many years.
Old May 16, 2012 | 07:05 PM
Dave804's Avatar
Dave804
The backrest tilting? I'm not sure, I'll investigate mine. Only recently found my fore/aft handle. I've got the school busateroal seat with at least 3 covers, all worn to the foam haha. One of the posh bench seats with the fold down arm rest in the middle Id go for. You know that newer seats and broncos will fit as well, right?
Old May 16, 2012 | 07:09 PM
jerd_hambone
Awesome. I'll look at what I can find. Should be able to find one to match my tan interior haha
Old May 16, 2012 | 08:01 PM
Franklin2's Avatar
Franklin2
Of course they tilt forward, that's how you throw junk in behind the seat on a regular cab. But be warned regular cab bench seats are not "finished off" on the back(no vinyl). I would think a extended cab with the jump seats would have a front seat that looked good in the back so the kids would not get their clothes caught in the wire and be able to pick at the foam that is exposed in a regular cab seat.
Old May 16, 2012 | 08:02 PM
jerd_hambone
I had an S10 that didn't have a tilt bench so I didn't know haha
Old May 16, 2012 | 08:19 PM
Fordzilla80's Avatar
Fordzilla80
Also keep in mind that Supercabs with stock bench seats have a split down the center of the backrest so that you can tilt each side separately of the other. On regular cab and crew cab bench seats, the entire backrest tilts.
Old May 16, 2012 | 08:27 PM
budford's Avatar
budford
Friend of mine back in college had a late '80's F-150 extended cab. The seat back would fold forward and inward towards center at the same time from each corner independently so you could get into the back from either the passenger or driver side. Not sure how to explain it other than that.
Never seen one like it before as all my trucks are regular cab.
Old May 16, 2012 | 08:28 PM
budford's Avatar
budford
Oops! Fordzilla beat me to it.
Old May 16, 2012 | 10:13 PM
Gary Lewis's Avatar
Gary Lewis
There is a cardboard trim piece on some of our trucks that makes the back of the seat look relatively finished.
Old May 16, 2012 | 11:24 PM
IntheTrees's Avatar
IntheTrees
The backrest on my bench seat doesn't tilt forward. There is no lever or anything.
Old May 17, 2012 | 12:16 AM
ctubutis's Avatar
ctubutis
I'm betting it does and you just haven't found the lever.
Not intended to be critical or derogatory or anything, it's just my opinion.
Could be that you have an aftermarket (or other) seat, though.
