Key ignition kills all power
Old May 16, 2012 | 01:54 PM
Daltonsheets1995's Avatar
Daltonsheets1995
I had to hook up a push button starter because when I turn the key in my truck it cuts off all power?? What in the world is going on?
Old May 16, 2012 | 01:56 PM
ctubutis's Avatar
ctubutis
If you are talking about all accessories shutting off with the key in START, this is done by design. It allows maximum power to the starter & ignition for starting the engine.
If you are experiencing something else, please be EXACT and SPECIFIC as to what is happening.
Old May 16, 2012 | 02:12 PM
lavatan's Avatar
lavatan
I am assuming (and we all know what happens then) that the truck will not crank when the key is turned but will when you jump the solenoid with the button. Could be your switch, a grounding issue, a short...
As Chris said, we need more information to truly figure out what the problem is. Also, did you recently change anything on the truck?
Old May 16, 2012 | 02:15 PM
Dave804's Avatar
Dave804
Do you have the stock alternator? If so can't help the feel that these threads are related to that 500w amp and sub install recently
Old May 16, 2012 | 03:36 PM
Daltonsheets1995
This has been doing this for months. It has nothing to do with the sub setup.
I have a hei dizzy so it has to have the 12v to give spark, well when I turn the key it completely kills that 12v. I hooked up a starter button to the solenoid and it starts fine
Old May 16, 2012 | 03:42 PM
ctubutis's Avatar
ctubutis
This tells me you hooked up the HEI to a power source that gets shut off with the key in START (by design, as explained above).
Which circuit did you tap into? What colors are the wires?
croy772
Jul 25, 2019 09:09 AM
Dwilson37
Jun 12, 2015 07:22 PM
95xltthumper
Oct 5, 2014 11:32 AM
RVbud
Apr 13, 2010 09:43 PM
beastybronco
1978 - 1996 Big Bronco
Aug 2, 2004 08:13 AM
