which fuse?????????? please help
Old May 16, 2012 | 08:47 AM
mntncat's Avatar
mntncat
Question which fuse?????????? please help
Which fuse controls the parking and license tag lights in 2002 Ford Explorer??? I can't find it in the wording of the owner's manual diagram.
Old May 16, 2012 | 01:48 PM
shorod's Avatar
shorod
So none of the parking lights, front and rear, work, as well as the rear license plate light? Does the instrumentation illumination work?
I'll check my service manual this evening. The diagrams I have remote access to are not showing me specifics for the parking lights.
-Rod
Old May 16, 2012 | 05:06 PM
87 XLT's Avatar
87 XLT
Does your owners manual show the location for the park lamp relay? It probably has one.
Do your park lamps flash when you use your key fob?
Old May 16, 2012 | 05:30 PM
mntncat's Avatar
mntncat
Rod, correct...none of the parking lights or license lights work and yes, the instrument panel is lit.
XLT, it does show a park lamp relay in the book, it says "(Export)" beside it and does not list an amp rating for it. And no, the lamps do not flash using the remote fob. Looking at the fuse box, there is nothing plugged into that slot.
Old May 16, 2012 | 07:07 PM
87 XLT's Avatar
87 XLT
Well i was hoping this might be as simple as a bad relay, but i guess not. I dont have diagrams for an 02, hopefully shorod will have them.
Old May 16, 2012 | 10:57 PM
shorod's Avatar
shorod
Interestingly, the parking lights and license plate lights all get their power from the same circuit that activates the headlights via the main light switch. Power to the main light switch is provided via fuse F1.16 (15A) in the Battery Junction Box (BJB). The same circuit that powers the parking lights and the license plate lights also power the LEDs in the door lock switches. If the door lock switches are all illuminated when the parking lights are on, this issue gets really challenging....
For vehicles designated as "late build" there is a parking lamp relay, but that is just to activate the parking lights when the security system is armed, disarmed, or triggered. That relay bypasses main light switch when activated by the security system.
It sounds like it's time to get out the test light or multimeter and do some probing at the main light switch.
-Rod
Old May 17, 2012 | 07:42 AM
mntncat's Avatar
mntncat
OMGOSH!! Rod, thank you so much!! Looking at that fuse showed that it is indeed blown!! Whew! I'm gonna go get one to replace it and hope that solves the problem.
XLT, thank you too for responding to me...you guys are great!
Old May 17, 2012 | 01:18 PM
shorod's Avatar
shorod
Hopefully a new fuse fixes the problem and blew due to a fluke. If the new fuse blows as well you'll get to pull out the test light or multimeter....
-Rod
Old May 17, 2012 | 02:00 PM
87 XLT's Avatar
87 XLT
Yep, looks like Rod nailed it. I'll keep my fingers crossed that the new fuse does'nt blow.
Old May 17, 2012 | 02:44 PM
mntncat's Avatar
mntncat
Thanks y'all! The new fuse is working so far!!
old farm truck
2009 - 2014 F150
Dec 27, 2017 06:14 PM
rlanicek
May 4, 2016 05:50 AM
iwritesql
Electrical Systems/Wiring
May 13, 2010 09:02 PM
CobraGT40
Aug 2, 2008 12:50 PM
rhondo
1983 - 2012 Ranger & B-Series
Feb 26, 2004 09:37 PM
