Inside door handles
Old May 15, 2012 | 11:06 PM
ReBilld's Avatar
ReBilld
Inside door handles
I have owned a bunch of OBS trucks, and a lot of them had broken inside door handles when I got them, or they broke on me. This is mainly due to the door hinge pins and bushings that we all know wear out and makes the doors harder to open, so we jerk harder and harder on the plastic door handles and......snap!
This our plastic handles.....
All of you may know this already, but the '80-'86 model trucks had metal door handles that don't break as easy and they bolt right in place of our plastic ones.
This is the early '80s handle......
They are chrome too, if you want a little bling in the cab....
Just a little FYI thread.....I just put hinge pins and bushings in mine this evening, and replaced the door handle I broke the other day
Old May 15, 2012 | 11:41 PM
nomad221's Avatar
nomad221
You've been busy Bill. Thanks for sharing. I know one of these days I'm gonna grab mine and snap!
Old May 15, 2012 | 11:45 PM
ReBilld's Avatar
ReBilld
Yep, it's usually just a matter of time LOL!
Old May 16, 2012 | 06:26 AM
DIYMechanic's Avatar
DIYMechanic
I have heard that the chrome ones are just pot metal and that they brake almost as easily as the plastic one. Has that been your experience as well Bill?
Another thing that can cause the handles to break is that the mounting tabs on the door can break and let the bracket for the handle move out far enough that the door latch mechanism doesn't release fully, causing you to have to pull harder and farther on the handle. The cable can stretch too, in which case twisting it in the direction that the cable is wound shortens it back up again.
This is a good reminder though.
I don't know why, but quite possibly my two favorite things about these OBS trucks are 1- the wing windows and 2- the door handles (inside and outside). They just work and look like they should on a real truck!
Old May 16, 2012 | 06:39 AM
Copedawg's Avatar
Copedawg
I use to snap them things ALL the time. Finaly, I replaced my door hinge pins and I haven't broke one since! Open your door door then lift it up. Did it raise up? If so, watch the hinge pins and do it again.
I'd change the pins. It worked for me
Good luck!
Old May 16, 2012 | 07:10 AM
Redneckmorton's Avatar
Redneckmorton
And its normally when its pouring down raining outside too.
Old May 16, 2012 | 09:33 AM
bad12jr's Avatar
bad12jr
The metal ones don't get as brittle in the cold. That's mainly when I have broken the 5 between 2 trucks. Metal now and no such problem yet.
Old May 16, 2012 | 10:02 PM
ReBilld's Avatar
ReBilld
Yeah, the cables are another culprit too. I just broke the plastic handle on mine the other day, but mine was due to pins and bushings being worn. I replaced those and it's better, but I'm gonna put the metal ones in when I find another set. They are pot metal or cast, but I've never broken a metal one before. I had a few of the early '80s trucks and I have put the metal handles in a few of my '90s trucks.
I figured about everyone on here already knew this, but changing my pins and bushings just made me think about posting this as a FYI for those who didn't know this was an option.
Old May 16, 2012 | 10:46 PM
farmert's Avatar
farmert
I broke 2 of the handles on the 97, as the cable was streching. Twisting the cable helped a little, but when the second one broke, my son made one out of a short piece of angle iron, and a length of 1/2" rod. He bent the rod into the shape of the handle, and welded it to the angle. A little red neck, but it works great, and no fear of breaking it.
Old May 16, 2012 | 10:49 PM
oldbird1965's Avatar
oldbird1965
Is there any way to lube the pins to prevent this?
Old May 16, 2012 | 10:50 PM
ReBilld's Avatar
ReBilld
Hey, whatever works right! That's pretty good engineering there, and I don't think that one will ever break!
Old May 17, 2012 | 01:10 AM
Oldsmoky92's Avatar
Oldsmoky92
I hear ya, the hinges in the cable assembly itself get worn and bind too i have noticed, then its 120 bucks and it works like new. I have installed 2 cable assemblies in 2 different rigs and both work great, a little pricey but worth it in my opinion. Some of you may not believe me but a friend and i acutally casted the plastic style handle out of aluminum, sounds crazy but it worked, looked cool and has held up great so far.
Old May 17, 2012 | 07:10 AM
DIYMechanic
I usually just use a white lithium grease spray on the hinge pins and bushings. It's a little messy, but it does a great job of keeping the hinges lubricated.
Old May 17, 2012 | 09:13 AM
oldbird1965
I just didn't think it would penatrate down in there, thanks Nate.
Old May 17, 2012 | 10:14 AM
DarkStarMedia's Avatar
DarkStarMedia
dorman makes a replacement cable for about $20 per side. A lot cheaper than replacing the whole latch when its just the cable
richard
