I have an 82 F150 with the TTB dana 44, my trucks registration recently expired, and since I am going to be home for at least 6 more months, I wanna do the SAS finally before I put it back on the road.
Found a solid 44 front from a 78, my 82's TTB has a limited slip with 3.5 gears, if the solid isnt a 3.5 ratio, can I swap the LS gear set from my TTB into the solid 44?
but the 78 axle will not fit without modifications.
if i remember correctly, the spring mounts are in different places.
The spring mounts are the same. The only thing is he will need the radius arm mounts and make a track bar mount for the frame. I have a 78 axle in my 95 and kept the 95's upper coil buckets.
