ok this is another question
Old May 15, 2012 | 04:17 PM
jerryst's Avatar
jerryst
I still have not been able to replace the clutch shaft on my 1955 f100. I am having a guy come over next week and cut it off with a torch. Here is my questions.
1 On the transmission side there is a fitting for a better word that is held on by a roll pin. Also there is a spring connected to it. Does anyone know if they make a reproduction of the fitting and the spring?
2 I really just need the spring because it will be in the way when the guy cuts off the shaft. But I am planning for the worst and hope for the best.
3 once the shaft is cutoff on the trans side it should slide out on the drivers side correct.
4 If the guy cuts it off should I have him super heat the fitting off the shaft to see if i can knock out the pin? Or take it to a machine shop and have them drill it out?
Thanks for any information and help on this. It bites that these small parts are holding me up.
Jerry
Old May 15, 2012 | 09:40 PM
sdetweil's Avatar
sdetweil
Jerry
Mid fifty has it all.
If u cut the shaft before the pin, why bother trying to remove it?
Sam
Old May 15, 2012 | 10:34 PM
jerryst's Avatar
jerryst
I agree with its not worth it to try and drive out pin. But its like a itch you just gotta scratch. I called midfiftys up and the lady who knows all the stuff is in texas. So I have to call back on Monday. Do you know the name of the fitting at the end of the clutch shaft?
Jerry
Old May 15, 2012 | 10:44 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle
That's the "end of the clutch shaft fitting thingy"
Just kidding...welcome to the forum Jerry!
Old May 18, 2012 | 04:15 PM
jerryst's Avatar
jerryst
well i finally got the clutch shaft off. i thought the shaft was hardened steel. but it was regular steel. so i cut it off with my trusty sawzall. now i am going to try and knock out the clutch pin. if not i will take to welding shop and have them heat it up and punch out the bolt.
jerry
grandpas 51 f1
Jan 21, 2013 08:36 AM
pineconeford
Dec 24, 2012 03:18 AM
danger-ranger93
Sep 19, 2010 11:34 AM
oldcoupe42
Garage & Workshop
Jun 28, 2009 07:29 PM
wolftan
Sep 14, 2006 03:13 PM
